Replacement Diamond plate?
solar07
Hello all,
We have a 2010 Sunnybrook 269THX. Sunnybrook being bought by Winnebago later in 2010, I am having a hard time finding certain things that aren't as RV universal. A couple of the factory Diamond Plate panels (I assume these are aluminum) on the side of the TT are bent/dinged up and I would like to replace them.
There is also a white metal trim on the rear corner that runs up to the roof I would like to replace that I also can't find but that is another question.
Does anyone make or sell these DP panels or am I left to having a machine shop try to duplicate them?
Thanks for any advice?
6 REPLIES 6
myredracer
If you can source the diamond plate somewhere on your own, a metal roofing company can cut and bend it. They have large power shears and metal brakes for custom forming pieces of sheet steel. Any metal supply shop that does fabrication can also do it and can also supply the DP. I think you'll find it won't cost much to have a shop bend it.
You could always bend it yourself using some say, 2' long pieces x 3/16" angle iron in a vise along with some HD clamps and using a rubber mallet. Slightly bend a section and move it along to the other end and repeat as necessary in small steps to get the required bend angle. By the time you buy the angle iron, it may not save any $$ and if you don't have a vise it's def. best to go to a shop. I made an 18" long bender like the one in the photo for car restoration and crisp & clean bends are possible without having to resort to a metal brake. Not worth the time and expense tho. for a 1 time project.
You might consider using heavier gauge DP to minimize chances of having to do this again some day.
On the white metal trim piece, maybe try asking a local RV repair/parts shop, otherwise a dealer may have it.
Pls post pics when all done... ๐Ÿ™‚
solar07
How do you (or did you) plan to cut and make the bends for the lip that goes under the camper for the screw holes? Mine has like a two inch lip inward on the bottom where the screws go.
time2roll
I have used metalsdepot.com Use existing as a template and start cutting.
westend
Discount Steel also ships and will cut to size. They have a yard in Mpls. and in Fort Worth.
'03 F-250 4x4 CC
fairfaxjim
Another source of DIY: CutsMetal.net
Jim & JoAnne
2016 Toyota Tundra SR5 TRD Double Cab
2004 Starcraft 11RT (Replaced by)
2011 Eclipse Milan 18CK Travel Trailer
Dick_B
Can you use these folks and DIY? http://diamondlifegear.com/trailer-stone-guard.htm
I'm seriously thinking about it for the front of my TT.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
