Replacement LED brake lights
Msu50000
One of the brake light housings on the trailer is no longer there, found that out when we got to the campground this weekend. Perfect time to replace with LED, I've done a quick search on eTrailer/Amazon with mixed results. I need something about 8.5" x 3.75". Most of what I'm finding are a bit smaller. Does anyone have any recommendations and also what type of sealant do I use once mounted?
2015 F150 Platinum (sold)
2018 F250 6.2L Lariat
2017 Coachmen Catalina 333BHTCSK
5 REPLIES 5
enblethen
The ones from Amazon look good!Link
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Msu50000
Found these, now that I've had a few minutes to look. They appear to be the same shape and style as what I have on there now with the LED instead of the old style bulb.
https://www.amazon.com/dp/B07DDNYZS7/ref=cm_sw_r_em_apa_i_3NU6CbGKP0RHC
midnightsadie
on the wires solder the joints then slide shrink tube over the splice.harbor frt has them .and e bay .amazon ,
Msu50000
Thanks Bud, the diagrams showed those lights slightly under 8" wide, I'll have to get the light off once I'm home and see what I have to work with, I've only measured the base plate for the light housing.
enblethen
Something like this?
Peterson lights
Bud
USAF Retired
Pace Arrow
