Replacing awning gas shocks
napanee_ted
I would like to know if when changing the gas shocks on my awning should I support the awning end that I am working on before removing the shock
5 REPLIES 5
GrandpaKip
Why take the chance? Supporting the awning ends should only take a couple of minutes.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
Colo_Native
I just replaced one of the brackets in mine and if you open the awning and support it (I use bungees tied to a 12" ladder) take all the pressure of the strut (shock)
2015 Winnebago Forza 34T
pushed by a 2011 Fusion Hybrid or 2020 Escape Hybrid
Retired DFD
Vulcanmars
MFL wrote:
While you are not giving much info on awning type/brand, I would support my Dometic electric awning before removing the shock. If I pull down to lower the awning end, it seems the shock is doing a lot of supporting. I have to say, that I have never replaced one though.
Jerry
X2- Need more info.
Mine (Lippert) are rated at 124 lbs. You need to support the end.
Mars
04 V10 F250 SDCC 4X4
2016 Wildwood 32BHDS
MFL
Nomad II
Nomad II
Jerry
Lwiddis
Support is good.
