โSep-09-2019 02:36 PM
โSep-19-2019 11:28 AM
trail-explorer wrote:
News article says "truck and Camper"... but that's a truck and travel trailer.
โSep-18-2019 04:05 PM
Grit dog wrote:
As usual, the speculators are out in full force.
Regardless of the cause, it generally centers around something no setup right, primarily too little tongue weight, however grooossly heavy tongue weight canhave the same effect and then it can be exaggerate by โwhereโ the weight is.
The takeaway that everyone should know IF it happens is get tension between the truck and trailer before itโs too late and it will straighten out. Typically manually applying trailer brakes, followed by t brakes and accelerating if that dont work. And in the event of no trailer brakes and itโs not coming back on itโs own, you have to floor it!
Another tip is DONT try to correct the sway all the way with steering unless you donโt have the room. You can buy some time and bring the trailer back if you can sort of โfollowโ the sway with the tow vehicle.
It happens fairly quickly but not too quick to recover if one know what to do in the event.
Yes Iโve had a few trailers get away. Comes from towing a lot at a very young age when this knowledge and the internet did not exist for me.
โSep-18-2019 01:53 PM
โSep-18-2019 10:08 AM
โSep-18-2019 08:39 AM
โSep-17-2019 10:27 AM
samhain7 wrote:
So to answer some questions, he has broken ribs, but that was from the airbags hitting him. He girlfriend has broken wrists..I guess a good endorsement for Dodge Ram 1500's...
As for what happened, he did have anti sway, but yes, it was a LARGE trailer. I suspected he was overweight, but I can't confirm.
So he was on the highway, and the trailer started swaying and he couldn't recover, and it flipped. That is all the information I got from his brother.
โSep-17-2019 07:08 AM
Walaby wrote:Lwiddis wrote:
That's one of the reasons I drive slowly.
See nowhere in article or follow up where speed (fast or slow) was even mentioned.
Glad no serious injuries.
I think the proper oil was used, but the issue, but chose regular vice synthetic oil to save money. Always buy and use synthetic oil, because you never know what will happen.
And, as momma always said, where clean underwear, just in case you get into a car wreck.
Mike
โSep-17-2019 05:50 AM
โSep-16-2019 11:13 PM
โSep-16-2019 08:17 PM
โSep-16-2019 02:01 PM
โSep-16-2019 11:04 AM
โSep-15-2019 09:39 AM
โSep-15-2019 07:18 AM
