Roof leak fixed but.....
zparnell
On my 06 Wildwood, the edge trim pulled away from the roof for about 6 inches before it started around the front downward. I fixed the trim and sealed it up stopping the leak with some dicor sealant.
The question now is, what about the dampness inside the wall on the front of the camper. Do you just let it dry or what? I can feel some weakness in the wall on the inside near the top.
2006 Wildwood 31BH
1988 Skyline Nomad
2000 Ford F250 Supercab 7.3
3 REPLIES 3
project_tenkill
In my expreince depends how wet, and how long its been leaking, could have rotted wood, or mold ,water logged insulation. On mine i had to remove panels . Let dry kill mold,replace insulation and panel with new
2012Coleman
Use a dehumidifier.
2018 RAM 3500 Big Horn CTD
dcb17b
Anytime I have had a leak I have opened up the area as much as possible to dry it out. It may require removing some wall board and/or insulation. I then place a small fan it the area and move as much air in/on or into the area. If you do not dry it mold will form. If you do not want to deconstruct your camper,at least put a fan in the area and try to move some air for a while. Getting into the area to see what is wet and see when it is dry is the BEST way to handle it.
2022 F-150 STX 2,7 Ecoboost
2023 Jayco 25RB
