โOct-16-2018 02:45 PM
โOct-19-2018 07:59 AM
mdhemrick wrote:mdhemrick wrote:
Is it OK to turn off a RV Refrigerator when not in use or is it best to remain plugged up? Thanks!
OK let me rephrase the question: Does a RV refrigerator need to run 24/7 or can I turn it off when not in use? If its turned off when not in use then the RV does not need to remain plugged in to an electrical outlet. The concern is getting the most life from the unit. Some where along the way I was told that letting one sit idle for extended periods of time wasn't good for one. Just wanted to visit the subject after purchasing a newer model. Thanks to those who have given positive input on the subject!
โOct-19-2018 07:51 AM
โOct-19-2018 07:07 AM
โOct-19-2018 04:01 AM
โOct-18-2018 12:42 PM
sgfrye wrote:2012Coleman wrote:Jay Coe wrote:
Plugged up with what? Toilet paper? Are you serious, or trolling? On when you use it, off when you don't. This isn't rocket science!
What would really be better would be if people didn't have to be such a-holes to someone asking a simple question.
x2
โOct-18-2018 12:08 PM
โOct-18-2018 11:49 AM
Jay Coe wrote:
I'm 56, college educated, retired electrician and work at a technical college and I've NEVER heard plugged up used for a plugged in electrical connection.
โOct-18-2018 06:55 AM
โOct-18-2018 06:40 AM
deltabravo wrote:
When I worked for a large inverter manufacturer, in tech support (answering tech calls all day), it was all too common for people from certain geographic regions of the US to use the phrase "plugged up" instead of "plugged in". It was mostly the folks from the Southeast
โOct-17-2018 09:43 PM
theoldwizard1 wrote:
If it is running on propane with a pilot light, that is a REASONABLE thing to do.
โOct-17-2018 09:38 PM
โOct-17-2018 10:39 AM
โOct-17-2018 09:26 AM
Beverley&Ken wrote:
I turned mine on in April of this year and will turn it off in the next couple of weeks when I finish winterizing. I still have food in the fridge and freezer, extra space from home.
Been doing this for 12 years now and no problems ever (touch wood) with the fridge.
โOct-17-2018 08:52 AM
