RV toliet
dadkins
I have a 2002 KZ Coyote Hibred. The floor of the trailer has gone soft and I have learned that this is a problem with this particular model trailer. I have removed all the linoleum and put 3/4 inch cabinet grade plywood on top. My quandary now is the bathroom. The toilet sits on the old floor which is shot. I want to recover the floor with the same material as the rest of the trailer. However, when I do this, the toilet will set almost 1 inch above the flange. Is there an adapter or something I can use to mount the toilet on the new floor and connect to the black tank? The toilet does not leak. It did previously from a cracked valve, but that has been repaired. I really need help on this.
Dave & Lesa, Arkansas Ozarks
2003 Dodge 1500, Quad Cab, w/Tow Pkg & 5.7 Hemi, Prodigy Controler
2002 Coyote 23 CMS Hybrid
If you're too busy to go fishing, you're too busy!
3 REPLIES 3
Executive45
Easy fix...get the spacers in the plumbing dept at HD. Nice project...take pics....Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
Monaco Executive M-45PBQ Quad Slide
525HP Cummins ISM 6 Spd Allison
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
JohnnyT
Moved from class A forum
2004 40DS02 Travel Supreme ISL 400
Jeep Grand Cherokee, Ford F150
M&G Brake & Break Away
Blue Ox Aventa LX Tow bar
rgatijnet1
Toilet flange spacers are available at most hardware stores or Home depot. These are used all of the time when the surrounding floor is raised due to new tile, etc.
