โDec-19-2021 10:11 AM
โDec-20-2021 05:34 AM
JimK-NY wrote:
I would suggest doing a bit more research. I suspect the GVWR of 10000# is more related to registration costs than to the actual load rating. States charge registration fees based on the GVWR and over 10000# can increase the charges.
โDec-20-2021 05:17 AM
โDec-19-2021 02:13 PM
โDec-19-2021 01:31 PM
notsobigjoe wrote:
If your 740 lbs over that would not bother me and many other truck campers on this forum and the rest of the truck camper forum universe. Then again the weight police would consider you massively over and in need of shaving off some additional weight. Where ever you fall in the middle of these two very different worlds is something your going to have to work out yourself. I'm not being snarky at all please don't think I'm being sarcastic. I'm usually over about 1500 pounds as well as a boat in tow and I could care less. If your comfortable with your rig then I say go with it, if your not then upgrade to the one ton. If I could give you some advice skip the 1 ton non dually and just get the dually. You'll be within every weight limit possible and you'll have the best ride out there. I hope this helps. Joe
โDec-19-2021 01:00 PM
โDec-19-2021 11:17 AM
JimK-NY wrote:
You are happy with your rig and have used it several times. What concerns do you have? What advice are you asking for?
It seems that weight is the issue. If so, I can add that my TC is supposed to be 2300 lbs empty and setup for travel it weighs in well over 4000 lbs. I take extended trips and carry backup foods, a generator, 2 solar panels, 2 heavy AGM batteries and 3 seasons of clothing. Your use seems very different and you are likely not too much over the specs for your truck. I would check on ratings for your tires. Those are probably limiting you to roughly 3000 lbs per tire. You might be able to upgrade to improve the safety margin.
โDec-19-2021 10:36 AM
