Oct-07-2013 06:57 PM
Oct-13-2013 07:32 AM
lawrosa wrote:
I think youll be fine... You have a little more truck them me and look what I pull.
Most important is the trans cooler. I fit the biggest one I could behind the grill.
If you have that tiny one that came with the truck replace it.
Otherwise your trans will not last long at all.
5500 tow rating...4100 trailer dry... WD hitch..
Truck only is 4900 GVWR with 2700 lb axles...
Now sway at all with double axle.
Oct-13-2013 07:16 AM
dlos wrote:
gmw, you bring up an interesting point, all vehicles have their limits. It also sounds like you have experience towing things. I do believe the manual trans helped your situation.
One thing not mentioned here by the OP, or you, is how many people and how much gear was going in the Frontier cab and bed. Even at 4000lbs, the tongue weight is going to start chewing heavily into the Frontier's payload which is not all that much.
If the OP is planning to pull more than 4000lbs and has wife, 1-2 kids, full tank of fuel - payload is maxxed or exceeded. That is unless mods have been made to the truck.
The Frontier is strong, it'll pull more than its recommended weight. I love mine, just wouldn't put myself on the road with a big box and a full or over weight load in the truck.
I'm not suggesting the OP get a new truck, just a camper that better matches the abilities of the truck and maybe leaves some room for the truck to perform better and have some reserves in power and brakes.
Oct-13-2013 03:32 AM
Oct-11-2013 12:20 PM
Oct-11-2013 09:12 AM
Oct-11-2013 06:42 AM
sunovertone wrote:
Thanks for all the advice! As much as I love the r vision trailer I decided to go with a smaller trailer. I really like the Springfield 202. It has a decent floor plan and is around 4000 lb.
Oct-10-2013 11:17 PM
Oct-10-2013 10:10 PM
Oct-10-2013 07:28 PM
Oct-08-2013 08:04 AM
Oct-08-2013 07:46 AM
Oct-08-2013 05:06 AM
sunovertone wrote:
Hello! I would really like to purchase a r vision 23rbs trail light travel trailer. It has a 23 ft box and 27 ft from bumper to bumper. I have a 2010 nissan crew cab 6 cylinder frontier. It can tow 6100 pounds. I think the pay load is 1116 or so. The wheel base is 126. I know I can tow 24 ft with my wheel base, but, I would like to know if I can tow safely 27 ft. I do not think weight is an issue, the trailer only weighs 4000 dry. I really like my truck and really want this trailer, but just need to know if is ok combo!
Oct-08-2013 04:46 AM
Oct-07-2013 10:30 PM
