Second battery option
cthompson
Is there any positive to getting a second battery in my truck if it has that option?
3 REPLIES 3
christopherglen
Only if you have lots of toys, or a diesel. Diesels have electric grid heaters and/or glow plugs to suck the batteries down right before you hit the starter. Gas rigs just have the heated seats and the starter. If you have a little self control you can start it before powering the seats. ๐Ÿ˜‰
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, Titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
KD4UPL
If you will are planning to install lots of electrical accessories, especially ones you will use with the engine off, it may be beneficial. These might include: winch, off road lights, high powered stereo, 2 way radios, inverter, etc.
If you're just going to drive it around like a car then I see no reason for 2 batteries.
stickdog
Are you planning on plowing snow?
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
โ€œA good traveler has no fixed plans, and is not intent on arriving.โ€ Lao Tzu
