โOct-28-2016 10:44 AM
โNov-20-2016 01:23 PM
SoundGuy wrote:goducks10 wrote:
You don't need electricity to make coffee out camping. We bought a French press coffee maker. All you have to do is heat up some water in a pan on the stove, once boiling just pour it into the press. The press won't keep it warm so we pour the coffee into insulated mugs.
Of course, but that has nothing to do with the real issue at hand - i.e. the fact that many wives just aren't interested in camping in an RV without shore power, and although dry camping aficionados will argue the point ad nauseam it won't change this reality in any way. :R My wife happens to be one of them - as long as I make sure the fresh water holding tank is well supplied and any grey / black that needs to be off loaded is taken care of by me she could care less BUT she doesn't want to hear about not having shore power available. :M Whether I like it or not my reality is we're going to be camping on an electric site if at all possible ... and for those few occasions when we may lose that power (for whatever reason) I've installed a 1000 watt PSW inverter that at least allows us to continue making coffee and toast just as we normally would. She can still use her hair dryer and I can run a couple of fans ... about the only thing I can't run is A/C but hey, it is what it is. :W As has oft been said, if she's not happy you can be sure you won't be either. :E The OP has declared a definite preference for camping on electric sites and as a married man myself I know precisely where he's coming from. Will that ever change? ... could, but I wouldn't necessarily count on it. :W That Coachmen Freedom Express 192RBS the OP has expressed interest in is a perfect solution for the type of camping the OP indicates he's likely going to be doing ... I should know 'cause WE have one. :B
โNov-20-2016 01:06 PM
โNov-20-2016 09:15 AM
โNov-20-2016 06:29 AM
cwmoser wrote:huachuca wrote:
What type of camping do you think you'll be doing? We camp year round mostly on public lands without hookups so holding tank capacities, insulation, battery reserve, furnace, vent fan, LED lighting, awning etc are important to us. If you'll be staying where WSE are available, these are obviously much less critical.
FWIW, we've found we spend very little time in our camper and, if we're in the campground, we're outside under the awning or in our screen room in inclement weather. The stove has been used only a few times for coffee and I don't even know if the microwave works. We did have a. custom mattress made for the bed and it's as good or better than what we have at home.
Good luck and keep us posted.
Al
Al, primary interest in Camping is currently "resort-like" campgrounds.
We might venture into more primitive camping - I'm open to explore
but wifey is a little reluctant. Maybe as we learn more we will
be more adventurous.
If camping means being without my morning Coffee, it ain't for me ๐
We have been mostly homebodies most of our lives and going to the
Beach, visiting relatives, or Disney World has been about all the
exploring we have done. Now that we are retired, I'm thinking we
need to find out if we have been missing a lot in life.
โNov-20-2016 06:26 AM
โNov-20-2016 06:22 AM
cwmoser wrote:
We have been mostly homebodies most of our lives and going to the Beach, visiting relatives, or Disney World has been about all the exploring we have done. Now that we are retired, I'm thinking we need to find out if we have been missing a lot in life.
โNov-20-2016 05:17 AM
โNov-20-2016 03:22 AM
Al
โNov-19-2016 01:59 PM
โNov-19-2016 11:34 AM
โNov-19-2016 07:53 AM
Last Train wrote:
Well, after all the flurry of information and discussion, it looks like you've had a happy landing. That Lexus ought to do fine - given your axle ratio and the transmission cooler - as a tow vehicle for the 192 RBS (or similar if you find what strikes your fancy).
I predict that you will be posting here about some fun adventures ...
โNov-19-2016 05:04 AM
cwmoser wrote:
Now that is some encouraging information.
Thanks.
Not sure why the 4.3:1 axle makes it a good tow vehicle but I like.
I'm assuming I will need to tow with the Over Drive OFF.
I've already wired in a Tekonsha Prodigy brake controller.
My Lexus LX470 does have a big Transmission Cooler located forward of the radiator.
โNov-16-2016 04:39 AM
cwmoser wrote:
Went to this calculator which calculates Engine RPM based on tire diameter,
Axle Ratio, and Transmission Ratio ...
http://www.crawlpedia.com/rpm_gear_calculator.htm
... and find that with Over Drive OFF at 3,400 RPMs that vehicle speed is
just over 68 mph.
With OD ON, the same RPMs should be 2559 - 840 higher RPMs with OD OFF. 33% more Engine RPMs, so I assume 33% less MPG. I typically
get 14-15 MPG - so I should expect approx 10MPG towing.
I'll have to take my LX470 out and verify that 3,400 is at 68 with OD off.
โNov-16-2016 04:19 AM
cwmoser wrote:
I read a lot that one should tow with Over Drive OFF - and 3-rd gear ratio in my LX470 is 1.000
โNov-16-2016 03:40 AM
