โApr-17-2016 04:41 PM
โApr-20-2016 08:02 AM
โApr-19-2016 12:13 PM
โApr-19-2016 10:18 AM
Colberjs wrote:That battery is fine for general use. So is Costco or WalMart.
So I guess we're battery shopping. Any recommendations on batteries? O'Reilly's had a comparable battery for $84.
โApr-19-2016 09:27 AM
โApr-19-2016 06:37 AM
โApr-18-2016 07:12 PM
Colberjs wrote:
I replaced that fuse and voila, power at the plug. Plugged in the trailer and had lights and slide action.
Sounds like you found and fixed the problem.
Does the battery charge off of shore power? Yes.
Would the 30 amp fuse being out prevent it from charging? Yes.
Now plug in your trailer to 110 and the converter will charge the battery.
โApr-18-2016 06:53 PM
โApr-18-2016 06:27 PM
โApr-18-2016 05:32 PM
โApr-18-2016 03:49 PM
โApr-18-2016 01:47 PM
โApr-18-2016 01:31 PM
โApr-18-2016 01:20 PM
โApr-18-2016 03:56 AM
Colberjs wrote:
I just went out and checked and nothing works on 12v only. There is a 30 amp fuse inline on a green wire coming directly off the positive battery terminal that is blown. I'm assuming this is the root of my problems. I'll try to find a replacement tomorrow.
