Slide out not going all the way in.
samhain7
Hi all. Noticed since day one our dinette table slopes a bit. Just happened to feel down the one side of the slide out and it does not close completely at the bottom.
It closed at the top and the other side is a tight seal.
Is this an adjustment thing from the dealer or am I looking at a major repair?
Final notice from MasterCard. Good! I'm sick of hearing from them.
2016 Dodge Ram 2500 Cummins, E2 WD w/sway
2015 Starcraft Autumn Ridge 289BHS
5 REPLIES 5
SoundGuy
samhain7 wrote:
Well. As long as it is just an adjustment I won't stress too much about it.
Which is why you want to have a qualified tech take a look, to determine if this is just an adjustment ... that's obviously not something anyone here can ascertain.
2012 Silverado 1500 Crew Cab
samhain7
SoundGuy
It appears your Autumn Ridge has a two year warranty so arrange to have your dealer look at it. Slide adjustment is unlikely to be covered but any issue related to the original construction of the trailer would be.
samhain7
Can't tell what system I have but that one doesn't look like mine.
And I should say it's not going all the way OUT. So when I extend it It does not push out all the way.
downtheroad
They can be adjusted...not a major repair.
Here is the manual with instructions on how to adjust...if it is a Lippert slide mechanism.
Look on pg. 9
Slide Manual>>>>LINK
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
