Jul-07-2016 03:08 PM
Jul-10-2016 06:54 AM
SoundGuy wrote:captnjack wrote:
Like many other issues we see mentioned here, for the most part, the people who don't have slides are worried about them and the people who have slides are not worried about them.SoundGuy wrote:
I'm guessing this slide owner and this slide owner might take a different view. :W
Easy to be an armchair quarterback when you're not the one having slide issues. :Rcaptnjack wrote:
But the people who seem to fear slide problems the most are the people who chose not to get slides. Which is fine since it's their choice. But if you don't have them you should probably not refer to problems with them.SoundGuy wrote:
Guess you need to pay more attention :S - I do have a slide. :Rcaptnjack wrote:
Guess YOU need to pay more attention. The sentence you reacted to was at the end of a paragraph aimed at people who DON'T have slides.
Nice try captn but you're going to have to do better than this. :W As I previously stated all the trailers we've owned previously has been non-slide but our current one does have a slide so we've been on both sides of the fence. Your comment that "the people who seem to fear slide problems the most are the people who chose not to get slides" overgeneralizes - the trailers we owned without a slide were chosen not because we "feared" slide problems but because at the time we were doing a lot of long distance camping and the last thing I wanted to deal with was the always present possibility of slide failure, whether leakage or mechanism issues. It was a rational decision based on common sense, not "fear". We now have a trailer with a slide and certainly one of the mitigating reasons we chose it is because we no longer long distance travel for weeks at a time as we used to - slide issues close to home are a far different matter than 1000 miles from home. Sorry captn, you're demoted to first mate. :W
Jul-10-2016 06:40 AM
Jul-10-2016 05:18 AM
Jul-09-2016 08:11 PM
Jul-09-2016 07:49 PM
colliehauler wrote:SoundGuy wrote:Cap'n jack, I have owned 3 RV'S with slides and had problems with 2 of them:M. The 3rd RV I traded after 1 year so no problems with that one:W. I guess that blows your theory out of the water:h. Despite having problems I will replace my seasonal with a model that has 3 slides for the room. The RV I use for travel to remote areas will NOT have a slide.captnjack wrote:
Jul-09-2016 07:23 AM
colliehauler wrote:
One problem is water damage from poor design. The shop I will use (hwy 33 rv repair) does several floor replacements a year. The problem is it does not show up until it's to late. If you don't keep your RV very long the problem most likly will never show up. They replace a lot of rubber roof's as well, most from tree branch damage.
Jul-09-2016 07:05 AM
RoyBell wrote:One problem is water damage from poor design. The shop I will use (hwy 33 rv repair) does several floor replacements a year. The problem is it does not show up until it's to late. If you don't keep your RV very long the problem most likly will never show up. They replace a lot of rubber roof's as well, most from tree branch damage.
I wonder if people with slide issues are operating them wrong? I learned from my dealer when I bought my pop-up to open the entire camper up first, before leveling. It's even more crucial on the pop-up because there are so many moving parts that are tied into the frame. Plus the frame was a lot less heavy duty because it's only carrying 3500 lbs vs 9K potentially.
I have followed this same method on my TT and have had zero issues. Makes a lot of sense. If you level the camper first, you may have the frame out of alignment. There has to be a lot less stress on moving components under a "natural state" vs having one side jacked up and possibly tweaking the frame and then deploying.
I know some manf. say to level and then deploy but that just doesn't make sense to me at all. Too easy to rip stuff up imo.
What I have done is gone to a flat parking lot and got the camper leveled while open. Then I close it all up and put the level bubble as being leveled. Obviously it's not level when closed as the slide tilts the coach a little. But, then it will be leveled when open.
Jul-09-2016 05:52 AM
Jul-09-2016 05:09 AM
pira114 wrote:
I think the only reason to not get a slide is for weight issues. Other than that, they're just as reliable as anything else on the TT
Jul-09-2016 05:03 AM
Jul-08-2016 10:58 PM
Jul-08-2016 08:22 PM
Jul-08-2016 07:41 PM
Jul-08-2016 07:35 PM
As for my anecdotal story what would lead you to believe this is operator error, especially when the rig had previously been into the dealer on two separate prior occasions because one or more of the slides weren't operating properly? This was the third time around, clearly something wasn't right, and the owner was rightly annoyed, particularly since he was so far from home. Easy to be an armchair quarterback when you're not the one having slide issues. :R
Jul-08-2016 04:25 PM
SoundGuy wrote:RoyBell wrote:
I have more issues with my electric awning than anything. After sitting it never works and I have to manually crank it once or twice and then it works all weekend.SoundGuy wrote:
Sounds like a loose connection somewhere. Any chance it's a Dometic 9100 that may be subject to a recall?RoyBell wrote:
Mine was made late '14 I believe as a '15 model.
I have brought it in for service once. They said the motor is weak. When it gets wet, it causes a little oxidation and the motor has a hard time operating when it's starting from a position like that. True or not I have no idea. Sometimes I can manually twist the roller and it frees it up. Other times I need to turn the nut and it works (makes me think it's not an electrical issue but mechanical). It's the model with the speakers built into the ends, whatever brand that is.
From your description it sounds like you may have a Solera Power Awning w/Speakers by Lippert Components. If so, and if this problem persists & your dealer can't resolve the issue I'd call LCI and ask for direction as to what to do about this to solve the problem. Scroll down that page I linked to and you'll see it says the awning can easily be retracted with a power drill. 🙂
