boop's avatar
boop
Slideout wall fail Lance 1121
Just wanted to expand on a post by Sleepy dated 7/10/2010.. I have a 2002 Lance model 1121.. I didn't realize the side wall was failing when I bought the unit in early 2018.. but by March 2019 it was failing to the point that if I had I not repaired it, it would have totally buckled as seen in other repair jobs.. at first I thought it was just an adjustment.. Thankfully I found sleepy's post and a few others identifying the problem.. My purpose here is to expand my fix to others who may have the same problem.. I was able to not only do the Unistrut fix I also added (without removing the siding) a brace inside on the refrigerator wall that greatly enhanced the fix! If I can figure out how to add pictures I will..
Thanks
