โAug-20-2019 03:08 PM
โAug-22-2019 09:17 AM
jimh425 wrote:This is about Li batteries.
Just be careful about adding batteries where they arenโt designed to go inside compartments. They weigh a lot and can tear the compartment apart.
โAug-22-2019 08:51 AM
โAug-22-2019 08:42 AM
โAug-22-2019 07:06 AM
Steverino54 wrote:
R...B...C..., how about a photo of the available space for the inverter, or, a better description of which drawer you are calling "cadaver drawer"? Thanks in advance.
โAug-21-2019 07:41 PM
โAug-21-2019 01:26 PM
RetiredBeanCounter wrote:
Death Valley, CA weathering 110 degrees every day. ..
โAug-21-2019 01:06 PM
work2much wrote:
I wanted a big battery but I didn't want to spend $1,000/100Ah of power so I went with a DIY battery for about half the price. If you have a generator as a back up even 200AH of lithium should serve you fine. That should allow for 200AH or so discharge rate, enough to run the coffee pot or microwave oven. If you need more start the genset. I built my system as a replacement for a generator so I wanted enough reserve for multiple cloudy days or camping in a shady forest. We have run the air conditioner but out typical MO is to move when it gets uncomfortably warm.
โAug-21-2019 09:13 AM
So do I want to spend the extra dollars for AC? Unlike work2much, I still have my generator, so overloading on solar/lithium is not as critical. But it is sure tempting to buy the big system knowing that, with these small batteries, I can fit it without disrupting storage.
โAug-21-2019 07:24 AM
โAug-20-2019 04:09 PM
โAug-20-2019 03:54 PM
โAug-20-2019 03:47 PM
โAug-20-2019 03:42 PM
