โApr-16-2015 03:36 PM
โApr-17-2015 01:22 PM
โApr-17-2015 12:29 PM
โApr-17-2015 10:29 AM
โApr-17-2015 07:56 AM
โApr-17-2015 06:00 AM
pianotuna wrote:Not necessarily. A proper MPT controller will get the most out of the panel under all conditions, not just when it's perfectly aligned. But you do need to get a real controller, not the cheapest thing at Walmart.
Adding a controller to an 18 watt panel would only make things worse.
โApr-16-2015 07:37 PM
โApr-16-2015 06:01 PM
โApr-16-2015 05:08 PM
โApr-16-2015 03:50 PM
BStrummin wrote:
1. Sounds like I can't expect much out of this panel, one calculation I found basically says 5.4ah/per day optimum. I guess this is basically a maintenance panel? For keeping up battery when not in use? YES
2. Is there a problem with it wired into the system? Would a cheap controller help? NO. NO.
3. Maybe they wired it that way just to run the fridge while on propane? Is it capable of doing that? NO, BARELY.
4. Do you think I can get away with running the furnace for 30mins/hour in the am? Only other use would be minimal LEDs and occasional water pump. MAYBE.
5. Would running my two vehicle (2014 f150) charge the batteries enough/or provide enough juice to run the furnace?YES
โApr-16-2015 03:49 PM
โApr-16-2015 03:45 PM
โApr-16-2015 03:38 PM
