โMar-09-2017 07:56 PM
โMar-11-2017 04:41 PM
hedge wrote:
I really don't see the point other than to save a few dollars in wire while you give up the ability to see the panel/lights of the charge controller. I'm not sure the area behind the fridge is strictly waterproof either with a vent above and on the side it seems like it could get wet.
however...I don't think it's that hard to remember to shut off the switch to the controller before turning off the main disconnect. A sticker by the cutoff as a reminder may be useful.
โMar-11-2017 01:05 PM
โMar-11-2017 10:05 AM
โMar-11-2017 02:10 AM
pianotuna wrote:
This is a poor choice. Run the extra wire directly to the bank. It is not expensive nor rocket science.dave17352 wrote:
In my last post I explained Renogy did indeed tell me to put a switch in line with the positive coming off the panels to make sure there was no power going to the controller when the battery is disconnected.
I will disconnect both the battery and the controller at the same time. When not in use.
โMar-10-2017 08:22 PM
โMar-10-2017 07:10 PM
โMar-10-2017 07:03 PM
towpro wrote:
To the original poster. I would call renogy tech support and ask them is it OK to disconnect the controller from the battery while solar panels are still connected?
Your only going to see power on controller with no battery if you were to pull camper outside before turning on battery switch. (which could happen)
โMar-10-2017 06:22 PM
โMar-10-2017 06:21 PM
dave17352 wrote:tattoobob wrote:
FYI the Fridge uses a ton of 12v power most people run the fridge on propane and save the battery power for the things the really need like lights and TV
Yep if you read my first post I make it clear I do not use the 12 volt heating element. This is still all up in the air. I may wire it the right way too! I really want a 12 volt fridge but that is going to wait a while I think. ๐
โMar-10-2017 06:11 PM
โMar-10-2017 06:09 PM
โMar-10-2017 05:56 PM
โMar-10-2017 05:46 PM
tattoobob wrote:
You can also call Renogy they have great customer support and can probably answer all your questions
โMar-10-2017 05:39 PM
โMar-10-2017 04:26 PM
tattoobob wrote:
Renogy 200 Watt 12 Volt Eclipse Solar Premium Kit up
I think you should spend the extra money and get the better panels with a MTTP Controller (I would also change the controller to a 40 amp.) Don't go direct from the panel to the fridge without going thru the charge controller
