โMar-15-2017 07:15 AM
โMar-17-2017 04:50 PM
โMar-17-2017 07:35 AM
โMar-16-2017 05:02 PM
ZeeLet50 wrote:
Soundguy, can you supply a link to those valves shown?
โMar-16-2017 03:29 PM
SoundGuy wrote:Bucky Badger wrote:
I cut the pex lines and used "Watts" (similar to shark bite) push on valves..no more caps for me
There no need to cut the PEX at all ... just buy a valve with a threaded end of the appropriate diameter & sex to match the existing termination on your low point drain lines. This one would screw directly into trailer's such as mine that use threaded plugs to seal the low point drain lines ...
... but female versions are also available that would screw on to a capped low point drain line.
โMar-16-2017 02:20 PM
โMar-16-2017 08:12 AM
SoundGuy wrote:GrandpaKip wrote:
Replaced ours with brass boiler valves with 90 degree shutoffs. Didn't want any more plastic hanging below and can attach garden hose to drain away from camper.
I open my low point drains once at the end of the season, why would I care about "draining away from the camper"? :h
โMar-16-2017 07:42 AM
โMar-16-2017 06:47 AM
โMar-16-2017 05:42 AM
โMar-16-2017 05:36 AM
โMar-16-2017 04:39 AM
โMar-15-2017 02:35 PM
โMar-15-2017 07:35 AM
โMar-15-2017 07:24 AM
