Voltage 50 percent
dave17352
I look around the internet and get all kinds of answers. What do you folks say the voltage is on a deep cycle battery that is 50 percent discharged. Open circuit that is, no load on it.
Does a AGM battery do better with deeper discharging and what do you all think is a safe discharge percentage on a regular basis with a AGM.
Also I just finished my solar install. My controller has three choices for the type of battery. 1 is flooded. 2. Is gel. Three is
sealed. I am assuming sealed would be the choice for my AGM. I called tech support at Renogy and the fella said it depends. I thought I would just get a straight answer. What would all of you say the choice is for my AGM?
Thanks for any advice.
Dave
NOW 2017 Leprechaun 260ds
2005 Forrest River Cardinal 29rkle FW
1998 Lance 980 11'3" TC
2017 CHEVY 3500 SRW 6.0
B@W turnover ball @ companion Hitch
Honda eu3000 generator mounted on cargo rack
Crestliner 1850 Fish Ski boat mostly fishing now!
11 REPLIES 11
time2roll
dave17352 wrote:
This is my battery. Duracell AGM
I think sealed is the right choice?
One other thing after reading a rather long and boring article looks like the best thing to do is plug my converter/charger in now and then and let it do its thing to keep my battery in the best shape. I have one of those high tech converter chargers from BEST converters. The reason I say this is because if you are using your solar you never really have enough peak solar time to float equalize and all that good stuff. When plugged into the grid you do.
Yes sealed seems fine. Renogy shows 11 different controllers so I read one at random.
Renogy Wanderer p15
Equalization at 14.6 once a month for 2 hours should be fine.
GELL charging voltage at 14.2 is a bit low.
Flooded should be avoided due to 15.5 equalization.
I disagree with the article. Solar is fine as long as you have sun. There are programmable controllers where you can hit the battery specs exact and will adjust depending on usage.
Converter PD with Wizard or IOTA with IQ controller is always fine to plug in.
Boondocker and Paramode are fine too.
pianotuna
Nomad III
Nomad III
The best of the best for everything but LI chemistries is the smart gauge. It becomes more accurate as it is used where as all the others drift out of calibration. A distant second is the Victron gauge--which is a LOT better than the trimetric and Xantrex
Regards, Don
trail-explorer
Voltage is a very inaccurate state of charge indicator for batteries. THere's so many variables involved, such as age of batteries, how long that have been at rest, how big the load was that was running on them, and the list goes on.
I'd recommend a Amphour meter for accurate battery monitoring.
Xantrex LinkLite or LinkPro are two that come to mind.
Bob
dave17352
towpro
that is what I like about my Bogart Engineering system. you can change every setting in the charge profle incuding turning on and off equalization charging.
My Universal Battery UB12900's (sold by Cabelas) show the following specs:
charge method (constant voltage)
cycle use (repeated use)
initial current 27A or smaller
control voltage 14.6-14.8V
Float use
control voltage 13.6-13.8V
2022 Ford F150
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Sold Forest River Forester 2401R Mercedes Benz. when campsites went from $90 to $190 per night.
time2roll
Exactly what brand is the AGM? They have different specs.
What are the absorption voltages of the three profiles on Renogy?
Still I would avoid anything with automatic equalization charge.
In the mean time safest is probably GEL.
work2much
We stay above 12.3 OV with flooded wet cell golf cart batteries. Renogy tech support is a joke.
2022 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2520 watts solar. 600ah lithium. Magnum 4000 watt inverter.
AnEv942
Everything Ive ever read about AGMs is they are NOT the best choice for regularly deep discharging- discharge should be more like down to 60%.
Holding charge on battery and discharge percentage in volts, regardless of type, is pretty much the same .
GELs charge at a lot less rate than Flooded or AGM batteries so a GEL setting shouldn't be used for AGM or flooded wet cell.
Not knowing what "sealed" is on your charger, though instruction/manual may show a charge rate chart which would help identify, flooded would be my choice unless 'sealed' closer (higher bulk & less float than gel)
'Depends' is a shrug and dunno-though in fairness no pat answer.
another good articlehttps://www.westmarine.com/
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page http://www.ourelkhorn.itgo.com
pianotuna
Nomad III
Nomad III
Voltage numbers may not be useful unless there is zero charging and zero load on the battery.
For AGM it is important to not exceed the gassing voltage.
Regards, Don
RoyB
For me being exactly at the required DC voltage has no meaning at all for me.
I use 12.0VDC as my point to start realizing my batteries are around the 50% charge state.
The charts for the wet batteries is like this I think...
Using the 12.0VDC here as the point to recharge back up to the 12.5 VDC point which is around the 90% charge state gives me great performance with my batteries. i.e. they last about the same time period when I am drawing around 23AMPS DC current during the 6PM to 11PM time frame each night doing this... When I do this including my parasitic drains I usually see around the 12.0VDC point at 8Am the next morning. This is when I will run 2KW Honda Generator connected to the trailer shore power cable to recharge my batteries back to the appx 90% charge in about three hours of generator run time. I don't have any solar panels going yet...
Thats all that really matters to me to be able to do the same thing the next day/night run off the batteries.
For me it really doesn't matter if I missed by a couple points...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
RoyF
This explains it all: the 12v side of life
