Drain line caps
rgnmgr
I needed to replace leaking water drain line caps on my 2014 Keystone Bullet. The drain lines are Red and Blue. That means they are Pex. Only Pex parts will work. After some research I located 1/2" Qest Pex caps at Fergusons Plumbing supply. The 1/2" plumbing caps at the big box stores do not work.
14 REPLIES 14
ZeeLet50
Thanks Soundguy ^^^^^
2017 Grand Design Reflection 303RLS towed by a 2016 GMC 2500HD gas with Andersen hitch and B&W turnover ball mount.
GrandpaKip
SoundGuy---because I want to.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
SoundGuy
ZeeLet50 wrote:
Soundguy, can you supply a link to those valves shown?
Watts Valve, probably available at big box stores like Home Depot, Lowes, etc.
2012 Silverado 1500 Crew Cab
Bucky_Badger
SoundGuy wrote:
Bucky Badger wrote:
I cut the pex lines and used "Watts" (similar to shark bite) push on valves..no more caps for me
There no need to cut the PEX at all ... just buy a valve with a threaded end of the appropriate diameter & sex to match the existing termination on your low point drain lines. This one would screw directly into trailer's such as mine that use threaded plugs to seal the low point drain lines ...
... but female versions are also available that would screw on to a capped low point drain line.
When I go to the store and that's what they have it works for me
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
and
2009 Nomad 3980
ZeeLet50
harley4275
SoundGuy wrote:
GrandpaKip wrote:
Replaced ours with brass boiler valves with 90 degree shutoffs. Didn't want any more plastic hanging below and can attach garden hose to drain away from camper.
I open my low point drains once at the end of the season, why would I care about "draining away from the camper"? :h
I like the idea of garden hose fitting on the end (and I have one on the cold low point),if not to drain away from rig , but to hook hose for washing anything outside with onboard pump or hooking up to black flush to rinse tank when there is no fitting on dump station hose.
2013 Sunset Trail 25RB TT
2015 Silverado 2500HD 4x4 6.0 l gasser.
Equilizer 4 pt
From Belle River, Ontario
2003 Mountain Star 890sbrx Truck Camper
SoundGuy
GrandpaKip
Kip
Andersen Hitch
Community Alumni
Not applicable
Thread tape won't fix it? You normally can get that for a few cents.
SoundGuy
ZeeLet50
I was looking for a solution to this also. I have a keystone TT and have the same caps you speak of. I like the watts solution shown above. I always seem to drop or misplace the caps.
Bucky_Badger
and
2009 Nomad 3980
Oasisbob
I put plumbers tape on the threads. Problem solved atleast on mine
Oasis Bob
Wonderful wife 3 of 4 kids at home. 1 proudly serving in USAF
2018 Ford Explorer
2001 Bantam Trail Lite B-19
HAPPY TRAILS:)
SoundGuy
Some drain lines are terminated with 1/2" threaded plugs, some with caps, and some with more convenient to use valves. Those 1/2" Qest may work in this situation but be aware that in general Qest piping that has long since been replaced by PEX in recreational vehicle manufacturing is sized slightly differently and in some cases won't work. For example, if you were to use a 1/2" Sharkbite fitting designed for use on PEX you'd probably find it would leak if used on Qest pipe.
