Sep-24-2017 11:25 AM
Sep-28-2017 12:07 PM
Reddog1 wrote:hedge wrote:1 You can control each motor individually. There are three toggle switches.
A couple questions.
1. can you control the individual jack motors individually?
2. why 2 motors on 1 side and 1 on the other? I guess I like congruency
2 Only three motors are required. I see a couple of reasons.
a Depending on which motor the are using, typically it will handle over 3000 lbs. One motor easily lifts one side of the TC and it saves the expense of the second motor.
b With one jack (motor) on one side the TC balances on that jack. The two jacks on the opposite side of the TC tilts (levels) the TC front to rear. All three jacks raise or lower the TC. You can raise or lower the single jack to level side to side or you can raise or lower both of the two jacks to level side to side.
c With one jack, on the driverside it can make it easier to access the fuel filler.
Wayne
Sep-28-2017 10:23 AM
A couple questions.
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Sep-28-2017 10:02 AM
SidecarFlip wrote:With the Stable Lift, you will loose the wobble experience, change your looks from a big potato with 4 toothpicks to a TC dragging a Swing set. :B
Wayne... Astute observation. A big potato with 4 toothpicks... Of course they wobble, part of the 'TC experience'....lol
SidecarFlip wrote:If you use the struts provided with the lift, you can bring it out of the corner and leave it at load height. It will not sway with the wind.
Why I park mine in the 'L' shaped corner between the garage and the shop. I can leave it at load height without fear of it 'blowing over' in the wind.
SidecarFlip wrote:From my forum experience through the years, some TCs can be used off the truck on the jacks and some cannot. Some can be stored off the truck on the jacks but not walked in while on the jacks. It is about how the TC is constructed. A given manufacturer may have models with different requirements.
Back to reality..
I know that Lance states that you can occupy (use) the camper off the truck (states that in the owners manual), at least I think it did in as much as I no longer own the Lance, I seem to remember that but...
Does that apply to all makes of truck campers? Not sure about that.
SidecarFlip wrote:That has nothing to do with the jacks. That is how the camper is constructed, the floor structure and its attachment to the sides. Totally unrelated to the jacks or Stable Lift.
I seem to remember Kayteg posting a picture of his Fleetwood (I think) off the truck and it showed a gap between the floor and the cabinets where the floor was bowing down, from, I presume the pressure of the jacks exerted on the sides, causing the floor to bow. Wouldn't occupying a camper that does that amplify the issue?
SidecarFlip wrote:Only the manufacture knows for sure.
My P'up don't do that but I remember his picture a while ago. My owners manual does not state one way or another about occupying the unit off truck, something I'll check out with Palomino next time I visit the factory which will be this fall as I need to pick up some upgrades I want to install.
Toad: 91 Zuke
Sep-28-2017 09:51 AM
Sep-28-2017 09:33 AM
notsobigjoe wrote:walkeraw's situation may be the same as mine. On my '96 Dodge SRW, the running boards hang low enough they were the controlling factor on how much ground clearence my lift had. As I recall, without the running boards I could have had an additional 1 to 2 inches clearence. I decided to leave it, and it never became an issue.burningman wrote:walkeraw wrote:
I didn't need to install the saddle brackets, since I have running boards installed.
Wait, what?? What have running boards got to do with it?
I've got running boards, they're no substitute for the brackets.
Yea, I was curious about this to. Can you explain a little more?
Toad: 91 Zuke
Sep-28-2017 09:22 AM
Sep-28-2017 09:04 AM
Freep wrote:Sharing thoughts on what is and what is not ugly can really cause hurt feelings. For example could you imagine being in a public place and telling someone they had an ugly baby and it was so ugly you would not have it? :B I think when you have a Stable Lift and you don't like the looks it is like one of your kids, you get used to it. Some people just do not like the looks of the lift. I personally do not like the white lifts on all colors of trucks. When I bought mine I had to pay $250 extra for black. Just my preference.Reddog1 wrote:
I also said I never would go back to "corner peg-legs", but I have. Went from my SRW 2WD to my new to me DRW 4x4. I had to remove the lift for the DRW. I have every intention to modify my lift from the SRW to DRW this winter.
Wayne
Please post plenty of pictures when you do this modification. I'm trying to convince my wife to go with the stable-lift but she thinks it's ugly.
I'm the one who gets to do the loading and unloading. Maybe I should get her to do it a couple of times and see if that changes her mind.
Toad: 91 Zuke
Sep-28-2017 08:36 AM
Wayne
Sep-28-2017 07:02 AM
Reddog1 wrote:SidecarFlip wrote:You kinda help me make my point, I'm not trying to be rude or cute but how do you respond to "poor ground clearance"? It is a legit question. Best I can do is 3 inches less than what you have or about 18 inches relative to jack travel.
Wayne.. You need to tell your 'wheeling' buds that your short wheelbase makes up for ground clearance. I've never seen a Sam high centered in anything....SidecarFlip wrote:Know you are getting personal. Ground clearance and big rocks don't need big engines. :B
Engine wise is another story.....lol
Sep-28-2017 06:24 AM
Wayne
Sep-28-2017 06:08 AM
Sep-28-2017 04:46 AM
Sep-27-2017 09:25 PM
Sep-27-2017 07:26 PM
Toad: 91 Zuke
Sep-27-2017 07:24 PM
