CONSTRUCTION
Before I made any of the rack's actual parts, I cut a test stake out of a short piece of 2 x 4. This turned out to be an excellent use of time and material because it helped me to set up tools and refine
methods.
![](https://farm1.staticflickr.com/547/19044677130_f81a100c30_z.jpg)
The stakes Were the first parts I made. I set up a stop block on the mitre saw...
![](https://farm1.staticflickr.com/372/19232311805_1b61bbec55_z.jpg)
... and cut the four stakes
![](https://farm1.staticflickr.com/511/19232312465_49e80d5887_z.jpg)
I marked the rear stakes 1.5" from the bottom...
![](https://farm1.staticflickr.com/508/19232313065_5f0922db92_z.jpg)
... and, with the band saw, removed the 1/8" that would allow them to fit in the rear stake pocket sockets.
![](https://farm1.staticflickr.com/306/19226401952_e03989c062_z.jpg)
Next, the sides of the stakes were removed...
![](https://farm1.staticflickr.com/547/19044731518_4daa0e8532_z.jpg)
... and the four stakes were cut.
![](https://farm4.staticflickr.com/3834/19226403282_8e0d899ef3_z.jpg)
Because the stake pocket holes have rounded corners, the stakes need to be rounded. For this I used a router table with a 3/8" roundover bit.
![](https://farm1.staticflickr.com/442/18609823704_f74433c13c_z.jpg)
Stakes rounded.
![](https://farm1.staticflickr.com/309/19226405292_15fa20eb73_z.jpg)
Here are the stake feet.
![](https://farm4.staticflickr.com/3834/19226406892_a11d216d30_z.jpg)
Stake feet and crossbars attached.
![](https://farm1.staticflickr.com/478/18609828204_3dcd69f1f8_z.jpg)
Time for paint. As with most all of our outdoor lumber projects we're using semi-gloss exterior latex. Three coats... durable finish, easy cleanup. Bill, you watching?
![](https://farm1.staticflickr.com/456/18611749033_83bef906b0_z.jpg)
Painting complete - time for another test fit.
![](https://farm1.staticflickr.com/338/19305418116_6411b5dd56_z.jpg)
Mounting the forward tie-down rings.
![](https://farm4.staticflickr.com/3701/19325448242_fcd533628c_z.jpg)
The front of the rack is secured to holes in the leading edge of the bed. This is a backup measure in case the front of the rack wants to lift.
![](https://farm4.staticflickr.com/3874/19373802192_6e82134458_z.jpg)
We already had two sets of Thule Hull-A-Port PRO folding kayak racks (I just call them J-racks). We bought a third set for Emily's kayak.
![](https://farm1.staticflickr.com/428/19331511935_d6f7ababdd_z.jpg)
There's just enough room to fit a 2 x 4 between the carriage bolts. The bolts, however, are too short AND they're metric (M6). We looked for replacements so we could use the stock knobs but nothing was
readily available so we converted to 1/4-20 and replaced the knobs with washers and nylock nuts. Here are the outer J-racks installed.
2008 Starcraft ST 2700BH behind 2013 Ford F-150 SuperCrew EcoBoost FX4.
Linked by
ProPride 3P 1400.
restcure.ca
