Super duty 10 speed gear ratios
4x4ord
Very similar to the 1/2 ton ratios. They are probably all excellent but my personal preference is that they would have left reverse as a higher speed. I think it was 1:-3.4 in the 6 speed
Super Duty
Gear Ratios
First 4.615:1
Second 2.919:1
Third 2.132:1
Fourth 1.773:1
Fifth 1.519:1
Sixth 1.277:1
Seventh 1:01
Eigth 0.851:1
Ninth 0.687:1
Tenth 0.632:1
Reverse -4.695:1
GM/Ford 10r80
1st 4.6957:1
2nd 2.9851:1
3rd 2.1462:1
4th 1.7690:1
5th 1.5201:1
6th 1.2700:1
7th 1.0000:1
8th 0.8536:1
9th 0.6892;1
10th 0.6357:1
Reverse - 4.8661:1
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
47 REPLIES 47
FishOnOne
All I could afford wrote:
I remember riding in the middle seat position between grandpa and grandma in the old Chevy 6.2 Liter Diesel, chugging along in the right lane and loosing speed on any inclines, as I watched the black smoke puff out in the mirror
I remember hauling some cattle to the Houston Livestock Show and Rodeo in a brand new 1984 Chevy C30 Crew Cab with a 6.2 diesel. Talk about a turd struggling to pull that cattle trailer even pulling in 3rd gear and don't even think about pulling in overdrive.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
Huntindog
Me Again wrote:
Huntindog wrote:
4x4ord wrote:
An interesting point when looking at the 10 speed in a new F350 vs the 6 speed in a 2015 model is this:
The max rear wheel torque at 1600 engine rpm in low gear (disregarding parasitic losses) in 2020 with 3.31 final gears is:
1050 x 4.615 x 3.31 or 16,039 lb ft.
In 2015 the max torque of the f450 with 4.30 final drive in low gear was:
860 x 3.97 x 4.30 or 14,681 lb ft.
It is even worse than you state. In 2015, all of the big three limited TQ in at least 1st gear to protect the rear end. A 3.31 is stronger than a 4.30. GM has publicly stated that full power is now available in every gear.
I haven't heard about the others yet.
That thing about diff gear would apply to the 4.615 and 3.97 tranny gears, with the 3.97 being stronger that the 4.615?
I don't know about the trannys.
The diff is the last piece in the driveline, so it has to stand up to the multiplication that has occured in the tranny and convertor. The deal with taller R & P being stronger is that as one goes lower the contact between the R & P gets smaller and weaker.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
All_I_could_aff
1999 R-Vision Trail Light B17 hybrid
2006 Explorer Eddie Bauer
2002 Xterra rollin’ on 33’s
1993 Chevy Z24 Convertible
Lives in garage 71,000 miles
4x4ord
Even more torque multiplication available from the torque converter. How much trucks have changed in the the last 20 years
The torque converter can double the torque output of the engine at stall speed but I'm not sure what the engine torque is at stall. By 1600 rpm there might not be much or any multiplication taking place through the torque converter.
You don't even have to go back 20 years to see how huge the difference is in low gear rear axle torque. In 2007 Ram was still using the 48re transmission. The Cummins was detuned to 570 lb ft at the flywheel to protect the transmission. (The programming allowed higher torque output at times to account for power being consumed by accessories on the front of the engine). Anyway the 1st gear ratio of the 48re was 2.45:1.
570 x 2.45 x 4.10 (final drive) gave an output of 5725 lb ft .... disregarding driveline losses.
B&W Companion
Me_Again
All_I_could_aff
Huntindog
Huntindog
100% boondocking
4x4ord
B&W Companion
valhalla360
Nomad III
Nomad III
4x4ord wrote:
valhalla360 wrote:
For the fun of it, I pulled up a gear ratio to speed calculator:
With the ford 2.7turbo, 3.73 rear end, 4.86 reverse gear and 32" diameter tires...30mph is 5710rpm. Redline is listed as 5800rpm...Assuming you aren't running around all day in reverse, this shouldn't harm the engine.
If you drop back to 25mph, it's a much more sedate 4750rpm.
So even with the really deep granny reverse gear, you can tow (push?) at 30mph on occasion (at least theoretically).
I'm still trying to figure out what scenario this makes any sense.
- If you have any significant room that the slightest mistake doesn't put you into the ditch/wall, it's easier to turn the rig around.
- If its a tight narrow twisty road where you can't turn around, you just increase the difficulty level 10 fold getting up to 30mph (regardless of gear ratio)
Update: Looks like if you have the diesel, you are limited to around 20mph in reverse as the engine is governed at 3700rpm.
I'm not 100% sure what the gear ratio was for reverse in 2017. 2020 6r140s have a -3.4:1 and I've seen values of both -3.12:1 and -3.28:1 for the 6r140 as well. I have the 3.55 axle ratio and I believe 34" rubber mounted on my 20" rims.
search gear ratio calculator...you can plug in your exact info.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
4x4ord
It's not just the additional 4 gears that will make the shifting behavior nicer on the 2020 but the flatter power curve as well. I think it will be interesting to see if the fuel economy of the new Powerstroke improves any.
B&W Companion
Grit_dog
Navigator
Navigator
2001400ex wrote:
blofgren wrote:
The 6 speed trans in my 2012 F150 work truck drives me nuts at times with it's constant shifting; I can just imagine what these ones must be like.......
I'm not sure how Ford will end up. But in my 2020 GMC Duramax. You really don't notice the shifts. The nice thing, since the spacing is less between gears, it seems natural. I haven't towed heavy other than around the block basically but it wasn't hunting the few minutes I was on the freeway. And you still have the option to lock out top gears.
blofgren, that was not a bad behavior in the first 6sp auto I had (2011 F150). But then again, I was totally enamored with it being the closest thing to an Allison 1000 that I'd ever driven up to that point.
But to your point, generally transmissions upshift as quickly as possible for economy vs load. Then you're in a high gear that can't support accelerating. Same deal with the 4L60 in our Tahoe, but with 33% less gears, it shifts less, understandably.
Even newer transmissions, like 400ex mentioned do seem more seamless, lol. Less of a rpm change and unless one is in sport or tow haul type modes, they generally shift VERY smoothly.
Haven't driven a new 10 speed light vehicle yet, but the 8sp GMs and Chryslers I've driven are smooth like butter when you want them to be and rip off great shifts when you want them to be aggressive.
IDK, maybe I'm just a proponent or sucker for more gears, but I'll take 8-10 speeds over 4-6 speeds all day long and twice on Sunday.
2001400ex
2017 Forest River Stealth SA2816
2020 GMC Denali 3500 Duramax
Anderson ultimate fifth wheel hitch
4x4ord
B&W Companion
Groover
Does anyone else remember this stunt?
Van Damme
I don't think that he was going 35 mph though.
Chuck Norris going well over 35 but forward
parody
I have Ford backup assist and it might work but I think that it has a safety interlock that would protest going over 20. I am not going to find out.
