โSep-24-2014 01:06 PM
โSep-25-2014 12:42 PM
Huntindog wrote:
If your springs are already over the axles, you can use lift blocks. I have done this on two TTs with excellent results.. As with any mod, it needs to be done right. I made my own blocks out of 1/2 " steel that I welded together 3 of for pieces with 1.5-2" of lift . Welded in a piece of steel rod for the mount and drilled a hole on the other side opposite it. If doing this, you may need longer U bolts. I wouldn't go too crazy with the amount of lift either.
โSep-25-2014 12:31 PM
โSep-24-2014 09:26 PM
โSep-24-2014 06:49 PM
โSep-24-2014 04:31 PM
โSep-24-2014 04:27 PM
AH64ID wrote:
In addition to flipping the axles some trailers have multiple attachment points they can use.
Any pics of your suspension?
โSep-24-2014 04:24 PM
โSep-24-2014 02:44 PM
โSep-24-2014 01:45 PM
โSep-24-2014 01:22 PM
