Apr-03-2014 05:44 AM
Apr-10-2014 09:57 AM
Apr-10-2014 08:26 AM
Apr-10-2014 07:05 AM
Apr-10-2014 06:44 AM
ah64id wrote:
I still don't think it adds up. Any 2500 that cannot maintain level with airbags is over the tire capacity unless the tires have been upgraded.
My dads 2500 takes 80-90 psi with a 2" level and 8K on the rear axle to be level.
If the OP feels he needs additional spring help over airbags on a 2500 there is something he isn't telling us.
Apr-10-2014 05:58 AM
Apr-10-2014 05:49 AM
Apr-09-2014 09:58 PM
Apr-09-2014 09:52 PM
Apr-09-2014 09:41 PM
Apr-09-2014 09:27 PM
Apr-09-2014 08:21 PM
Apr-09-2014 06:32 PM
Apr-09-2014 06:28 PM
Apr-09-2014 06:18 PM
ticki2 wrote:
I would agree with your spring shop , the bottom heavy leaf is not meant to be engaged all the time . It also acts as a limiter for spring rebound . Keeping the overloads ( lightly ) engaged refers to upper overloads on one ton trucks , not the bottom leaf .
I also agree with the previous poster . In order to accomplish your stated goal , sway side to side , a heavy duty sway bar is in order . The springs and things added to them are for carrying the weight. If you add enough to the springs , whether leaves or add on's it will eventually help the sway , but you will have one very stiff ride .
It seems you are trying to accomplish two different things , one is the added weight of the new camper the other is the sway that extra weight is causing . I don't think a single mod will accomplish both . That's my 2 cents . Following along.
Apr-09-2014 01:31 PM
