tail lights
samsontdog
I have a Gulf Stream TT 2012 year and I am having problem with the left turn signal. It is not working then I can tap on the cover and it will come on. I checked the connections and the bulb which were ok. How do I check further ? I can go back to the TV and check the right side then the left which is not working again. Hard to know if
when it is working or not. HELP
samsontdog:o:W
4 REPLIES 4
samsontdog
How can you get help
when you move it and not say where too ?????
samsontdog:o:W
1492
Moderator
Moderator
Moved from Forum Technical Support
samsontdog
Big Don 53 wrote:
Most times it's a grounding problem. I am sure you check it out with the HOT wire ID'er to test it and it most probably worked fine. It's got the hot side but the ground side is the problem. If you can clean the contact or put some WD 40 in there that will help get contact or you can run a wire from your frame and ground the outside of the socket and get it working or you might have the plug in type lights and it's one of them wires that's failing you .. I work on old AM radios and most of the time it's a grounding problem
Don
Thank you Don, I will check that
samsontdog:o:W
Big_Don_53
Don
If you think the grass is greener on the other side, then you need to water your own grass
