Thermostat Problem
augustpilot
Have 30ft trailer. Turn the thermostat down at night to 60. Wake up and turn up the thermostat, things have worked well until 2 days ago. Now when get up turn up, nothing happens. I then go to just fan and fan comes on. Turn back to heat and it starts working normal for rest of day. The thermostat is basic with the slide bar to set temp.
Brand is Coleman Mack. I am thinking problem is in the thermostat and not furnace. Checking to see if anyone has had this problem with trailer. If so what did you replace old thermostat with. Thanks.
2017 Rockwood 2906WS Ultra Light
2014 Dodge Ram 1500 5.7. 4x4
Firestone Air Lift 1000, Equalizer Hitch
6 REPLIES 6
augustpilot
FIXED. LATEST UPDATE
This is good information. The tech talked me through this on the phone. The thermostat is Coleman Mack. This fix applies to manual or digital box. Take cover off, take out fuse, there is only one, leave out 5 minutes. The unit reprograms it self. ,put fuse in, now works. Thanks for the response
Jim
1911_F-350
I think YouTube has a video for everything.
http://youtu.be/Hrsu0t0IOU4
06 F-350 DW 4WD
2016 Conquest 260RSL
augustpilot
Update to my post, this morning fan on furnace runs in beginning but no light off. Now looking as if problem is in furnace. Will have to call a tech to come out. We are in Tucson for winter.
Old-Biscuit
smkettner wrote:
I believe Coleman also makes a digital replacement.
Yes they do....roughly $65
Hunter, Honeywell or LUX digital....roughly $25
time2roll
Old-Biscuit
Is it this one.........
Coleman Mach to Honeywell Digital T-stat....ones that use AA Batteries
Coleman Wiring
Red = +12vdc
Blue = -12vdc
Green = Fan High
Gray = Fan Low
White = Furnace
Yellow= Compressor
Coleman to Honeywell
Red = +12vdc -----'RC/RH'
Blue = -12vdc NOT USED/Tape off
*Green = Fan High ----'G'
*Gray = Fan Low ------'G'
White = Furnace .....'W'
Yellow= Compressor ,,,,'Y'
*Green and Gray are used for the A/C Unit fan speed
If you do not install/modify your thermostat with a mini switch to have/use both Hi-Lo fan speeds just connect GREEN (Fan High) to 'G' terminal
Coleman Mach to Hunter Digital T-stat......ones that use AA Batteries
HERE is Link to Instructions
Many folks have replaced their analog t-stats to digital t-stats.
I did 8 yrs ago in our 5vr
Great mod! And easy to do.
