โSep-22-2017 04:22 AM
โJul-06-2024 05:12 PM
We also have a 2011 Puma trailer with a Thetford Aqua Magic V. We began having the same issue with smell coming into the bathroom (got worse when you sat on the seat). What was even more interesting is that the toilet holds water indefinitely, so I knew the flush plate and seal were fine. Oddly enough, after dealing with the smell during our last camping trip, I made up my mind that I was going to get to the bottom of this when we got home. Before we left the campsite though, I gave the whole inside (underside) of the toilet a good scrub and spray so it would be clean to work on. Interestingly enough, I noticed water on the floor behind the toilet when I was done cleaning it (and I know for certain that it didn't come from the outside). I was convinced that it was the bowl-to-floor seal. After removing the toilet from the floor, I decided to clean it even further now that I had access to it from the bottom. With the toilet now upside down, I filled it with a bit of soap and water to give it a good scrubbing - and THAT'S when the problem reared its head. The water was coming out of the seam at the top of the toilet where the base of the toilet is fitted to the top of the toilet. In earlier models, this was assembled with screws and easy to disassemble. The seal between the two was just a clay duct-seal style of material. With this model though, they decided to permanently bond the two together. This is all fine and dandy unless it's a poor bond and the two parts start to separate! This explained why the gases were worse when sitting on the toilet as well as the water on the floor after cleaning it. My solution was very simple. With the whole toilet now super clean and dry, I used a product made by DAP called Ultra Clear. It's a flexible sealant that dries crystal clear and is immediate water ready. It's the best stuff I've ever seen! I simply ran a bead of this along the seal making sure that it fills the joint between the two pieces. Although the floor seal looked good, I replaced it with a new one anyway. Before I put the new floor seal on the bottom of the toilet, I covered the WHOLE seal with silicone grease (must be silicone as anything petroleum-based will deteriorate the seal). Do not use silicone spray, you want silicone grease as it will stay put and create an absolutely water and gas-tight seal where the toilet meets the floor. This same grease is also perfect for lubricating the flush plate and seal! It's been several trips since I had done this and we've never had so much as a whiff ever again. Hope this helps you out in your endeavor to rid your RV of this common problem.
โJul-07-2024 04:40 AM
Looks like you provided the same response to different threads. Like the other one, this thread is very old.
โSep-27-2017 04:03 AM
โSep-26-2017 08:28 PM
nextlevel wrote:
I don't have a backflush option on this trailer. I bought a flexible wand to go into the toilet. Seems to work well.
I also do not put the paper into the tank. I keep a small trash can by the toilet with a spring loaded lid. I put a plastic bag inside the can and put all of the paper into the trash can. It never smells and I can use whatever paper I want to. I got the idea from another RV owner.
โSep-26-2017 12:13 PM
pauldub wrote:
If the toilet is working correctly, it doesn't matter how dirty or stinky your tank may be so don't get distracted by everyone wanting you to clean your tank. I have zero odor leakage after discarding my Aqua Magic and replacing it with a Thetford Style II. Replacing the flange gasket didn't help. Somewhere in the housing of the Aqua Magic is a leak and the whole housing is open to the tank. The leak may be around the flush pedal linkage. You'll see how lousy of a design the toilet is when you pull it out. There's no sealed connection between the bowl and waste chute. If you look online for pricing (hint PPL), you'll see that there's no reason to buy the Aqua Magic over the higher end Style II.
โSep-26-2017 10:54 AM
โSep-26-2017 03:46 AM
โSep-25-2017 07:38 PM
โSep-25-2017 07:29 PM
โSep-25-2017 07:21 PM
โSep-25-2017 05:57 PM
โSep-25-2017 01:10 PM
โSep-24-2017 07:25 PM
โSep-24-2017 02:34 PM
