Having just returned from our trip up to and back from the Black Hills/Mt. Rushmore area, we are in the general inspection/clean up mode to prepare for our next trip. Saw on our left rear tire on our tandem axle unit a pattern of uneven tread wear; i.e. the inside treads were definitely wearing more-so than the outside surfaces of the tire. (All three of the other tires show completely even tread wear.) No other anomalies are evident; i.e. no scalloping/cupping, etc.. The tires were inflated to the factory spec of 50 psi prior to the trip and have maintained that psi throughout - even to just moments ago when I checked.
The photo perhaps does not show the level of my concern, but there is definitely uneven wear. A friend who is a Class C driver confirmed this with me on Saturday.
So what might cause this?
A quick visual inspection of our leaf springs did not show any abnormalities - though I did not apply any kind of tool nor manipulation to them. The 192 RBS has tandem axles, but they do not appear to have any kind of adjustment available to them like camber or toe-in.
These are the original equipment, China made tires that have just over 11,000 towing miles on them. Their date code tells me they were manufactured the second week of 2015.
In a thread about a month ago I noted then my concern about these tires but went ahead on our 3,474 towing journey. Given what I've learned from others of you, it is time to replace these with perhaps a set of Goodyear Endurance shoes or similar. Nevertheless, if there is something amiss with our running gear, I don't want to see this kind of problem replicated with a brand new set of tires.
Thoughts?
2016 Coachmen Freedom Express 192RBS
2018 RAM 1500 Ecodiesel
