Jan-22-2020 11:50 AM
Jan-25-2020 02:07 PM
Jan-25-2020 01:47 PM
B.O. Plenty wrote:
I have them on my 2015 Chev dually. I installed them to smooth out the transition from it bouncing on and off the overload leafs. Before I had them it was real harsh when it hit larger bumps. Now it works well. I was told by Timbrens I could try them and if I wasn't satisfied they would take them back. Much nicer than airbags, nothing to mess with. Happy with them.
B.O.
Jan-25-2020 10:20 AM
cummins2014 wrote:ford truck guy wrote:Cummins12V98 wrote:ford truck guy wrote:
I HAD Timbrens,, I now have AirLift 5000.. Not sure I would go back to Timbren Style... Although, I like the idea of being lazy and not wanting to air up and down each tow...
In cab controls! Air compressor under along with air horns = GOLDEN.
YUP... reached out to Airlift folks to see when they would have fitment info for the 2020, as they are not showing any.
Was debating on putting the wireless in the new truck when it comes in
Wireless is the only way to go , I run the Airlift 72000 Compressor system. No air lines ,electrical etc inside the cab, just the remote control. And the nice thing about it ,not at the mercy of whatever a OE system wants to do. Complete control of air pressure ,ride height etc.
Jan-25-2020 09:23 AM
Jan-25-2020 09:18 AM
Jan-25-2020 07:05 AM
Jan-25-2020 04:54 AM
Jan-24-2020 01:32 PM
Jan-24-2020 10:48 AM
Jan-24-2020 10:16 AM
Aka the breeze wrote:
With all that said, my truck sits a bit low in the arse when towing.. I wanted to ride level when towing.... Just thinking out loud I guess...
Jan-24-2020 10:15 AM
IdaD wrote:Cummins12V98 wrote:
From everything I have read you will NOT be happy going from bags to Timbrens.
With my 11 HO DRW RAM I ran 5psi unloaded with stock like ride. With 4,500# pin added the pressure went up to 30psi and was enough to keep the truck "LEVEL" and setting on overloads as it was designed to be. Rode GREAT!!!
I had in cab controls with separate side controls to make minor adjustments.
Adding bags and Bilstein's made the loaded ride AWESOME!
Too many "THINK" they need to air bags to have trucks rear when loaded at unloaded ride height. BAD way to go.
This. ^^
He read that Timbrens suck, so based on no personal experience you should buy what he owns instead. Hang around here long enough and you'll figure out that whatever this guy owns is the best.
The best, Jerry.
The best.
Jan-24-2020 10:01 AM
Jan-24-2020 09:57 AM
Jan-24-2020 09:37 AM
Jan-24-2020 09:10 AM
