Oct-31-2018 04:56 AM
Nov-01-2018 07:53 AM
Nov-01-2018 06:59 AM
Nov-01-2018 04:55 AM
Huntindog wrote:dragr1 wrote:Dexter states 3" minimum!azdryheat wrote:
I would consider, instead, an LT truck tire over any trailer tire.
I’ve only got about 2.5-2.75” of clearance on top of the tires before they rub on the bottom side of the slides while the slides are in for traveling . So I don’t have enough room to go from my current 225/75/15 to a 235/80/16 LT tire like I would like to do. However I was just looking at a 225/75/16 load range e LT tires and I would only lose 150 pounds of carrying capacity per tire over my 15” load range e st trailer tires. And only gain 1” of overall tire diameter so I think they will fit. I might do this and drop these old trailer only tires.
You are already under that, assuming your measurements are correct.
It is not hard to get more clearance. An axle flip, or lift blocks work very well and are worth the effort IMO.
I ditched ST tires in 2005, and have been trouble free ever since. This new crop of STs MAY prove themselves over time.... But I will not be part of the experiment. I have already given those same companies too much of my money for tires that they then said were great.... Fool me once, shame on you. Fool me twice, shame on me.
Nov-01-2018 02:33 AM
Huntindog wrote:Ralph Cramden wrote:B.S..phillyg wrote:
Search on "Maxxis" and see numerous blowout reports. So far I've only seen one negative on Endurance.
Wait......how long have they been on the market? And its been a much shorter time that certain RV manufacturers have been equipping them as OEM. Even being used OEM thats not all that many units with the largest percentage being pulled to a campground 50 miles away a few weekends a season.
Most tire failures are not the tires fault, usually operator error which no one will ever admit on an RV board, or overloaded for whatever reason.
Too many of us have had success swapping to LTs, and the problems stop cold.
Nov-01-2018 01:49 AM
Nov-01-2018 01:46 AM
Nov-01-2018 12:22 AM
Oct-31-2018 10:02 PM
Oct-31-2018 10:00 PM
Oct-31-2018 08:49 PM
ken56 wrote:
Both are good, both have had blowouts.
Oct-31-2018 07:48 PM
Oct-31-2018 07:22 PM
Oct-31-2018 06:53 PM
Oct-31-2018 10:58 AM
Oct-31-2018 10:29 AM
