If only one tire and other three look relatively fine, could be a loose wheel bearing, bent spindle, possible overload, maybe bent axle, dragging brake, incorrect psi or suspension problem. Take it to a reputable frame and axle shop and get the alignment checked and also inspect for other issues. Won't cost that much and could save you a lot of trouble and expense down the road.
Age, mileage & history on tires? What does the tire wear look like? Even all across? Lippert
tire wear chart. Another tire wear chart
here. I helped someone change a tire on their TT last summer which was evenly bald across the tread. Turned out he had a badly loose worn bearing - courtesy the PO who did a bearing repack.
I wouldn't be blaming Chinese tires straight off without digging deeper first.
