โMar-08-2016 05:51 AM
โMar-24-2016 12:47 PM
jonmacs22 wrote:How much clearance do you have now?
Voicing concern as I believe others have here as well. The number of load D options now available to people who can only run 205 75 14 size is now next to nothing. Seems like the Chinese maker Kenda is the only one left as Kumho has stopped importing the 195R14C tire anymore.
I simply do not have enough space (clearance) to upsize to a 15" rim. Any and all help and guidance would be truly invaluable.
Many thanks
Jon
โMar-24-2016 12:03 PM
Many thanks
Jon
โMar-24-2016 07:52 AM
โMar-22-2016 05:43 PM
TexasChaps wrote:kennyd63 wrote:TexasChaps wrote:downtheroad wrote:
The tires you put on your trailer MUST be rated to carry the GVWR (gross vehicle weight rating) of you trailer.
You should not use "regular" passenger tires on your trailer.
I doubt you can find LT (light truck) tires in the size (I'm guessing 14 or 15 inch wheels - probably ST205/75D14 ) that are on your trailer....so you will have to stick with ST tires.
Most all ST tires are made in China and have a shaky reputation.
Many of us have had good luck with Maxxis 8008 tires.
and yes...nitrogen is pretty much of a hype.
I disagree.... I have 14 inch wheels and found a better rated LT tire..
however.. the op's tire size is still unknown at this time..
If the op would kindly post his tire size and TT gross weight we might better advise him.
TexasChaps The size for my T.T tires are 205/75R14
However the sticker on the outside of the unit says GVWR 7,620LBS, and the sticker inside of the manual says GWVR 6,000LBS which one is correct?
I would opt for the sticker on the unit. A GVWR of 7620lbs minus the hitch weight ( say 750lbs ) gives you 6870lbs on your tires so you most likely have 3500lb tandem axles. 14 inch tires typically come in load range C or D at best, load C is 1760lbs ( 4x = 7040 ) and is what the TT most likely came with as it's the least expensive option and has practically no safety margin. ( a few percent at best )
Load D is 2270lbs so 4x = 9080lbs.. ( around 30 percent margin )
Without starting another ST/LT tire war, I would suggest a load D LT and there are very few of them at 14inch size unfortunatley.. I personally have no faith whatsoever in ST tires and have always used LT's.. ( and coincidentally never had a blowout.. ) as long as the rating is greater than your max load and they have a bias ply type tread you will be ok.. I have used the Maxxis ue168n bravo truck tire for many years with no issues. Part # is: TL12458000, size:205R14C, service rating:109/107Q, and load capacity:2270lbs
โMar-22-2016 09:08 AM
โMar-22-2016 05:50 AM
โMar-16-2016 07:49 AM
โMar-16-2016 07:22 AM
โMar-16-2016 06:34 AM
โMar-11-2016 08:35 PM
gmw photos wrote:Olli wrote:
So when in doubt or don't have any preferences, get Maxxis 8008?
I prefer not to function that way. When in doubt, I research, until I have a preference based on more than just guessing what might or might not be best.
โMar-11-2016 03:49 PM
โMar-11-2016 11:21 AM
โMar-11-2016 02:09 AM
FrankShore wrote:
You can't and should never use passenger car tires on your RV!
Try some Maxxis tires like suggested and don't worry about filling them with anything than plain old air.
โMar-11-2016 02:07 AM
Huntindog wrote:Olli wrote:Maxxis has their issues.
There has been a disturbing amount of failures reported on this forum, at least for the small sample size it represents. Maxxis has a small percentage of the TT market, and this forum is a small percntage of that market.
This small slice of the market that is represented here has some very vocal Maxxis fans though.
But even the Maxxis fans (most of them anyway) will admit that Maxxis has an important shortcoming. Avaialability.
Almost everyone has to order, and then and wait to get them.. And when they finally do get them, sometimes they are very old.
Old tires are always a bad thing.
Having to wait for tires can be a bad thing... Sure, when making a planned purchase of an enrire set, a few weeks can be no problem..
But if a road hazard destroys a tire or two on a trip, then one can be stuck waiting for the replacements to arrive. Any tire can meet such a fate, so this concern has nothing to do with the quality of the tire.
This was a major factor in my decision years ago to do whatever it took to get 16 rims and LT tires.
They are easily available everywhere. I have never had a failure, but I recognize that it is possible. Being stuck somewhere waiting for tires would be a major problem for me.
If you are retired, or in a situation where you can be time flexible, then this would not be a concern for you.
