TOW TRUCK
M_GO_BLUE1
My 1-ton dually 4WD diesel pickup needs to be towed to the dealership...
The tow truck driver showed up with a regular (not flat bed) two truck and plans on towing it with the front hooked up...
I ALWAYS THOUGHT A TRUCK THAT SIZE WITH 4WD NEEDS A FLAT BED TOW TRUCK...is that true? and also with the way he is proposing it can it be towed the way he is proposing to tow it?
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
23 REPLIES 23
shum02
Threw my tensioner and serpentine belt last spring on the way home. Had the truck flat bedded to my house. I would not want it towed to far with the rear wheels down without the drive shaft being disconnected.
2006 F350 Lariat FX4 CC 4x4 PSD
2007 KZ2505QSS-F Outdoorsman
M_GO_BLUE1
Only being towed about 5 miles to dealership...
Tinyandthegang
Pull the rear drive shaft, lift the front and tow it as far as you want.
carringb
The NV-271 Transfer case may be towed rear down or 4-down if the T-case is placed in Neutral. You can tow the truck front-down (from the rear) with the T-case in 2WD and the truck in park, however there are distance limitations.
Most reputable towing companies use Industry standard towing guides which list the available towing methods for every make and model out there.
2014 ORV really big trailer
2015 Ford Focus ST
Vanished
I saw a Ford Dually 6.0l getting pulled with a tow strap up the main road by a newer Ford Dually this week... So anything is possible.. (and no this wasn't a 6.0 bashing moment) 😉
2019 Ford F350 4x4 diesel DRW
2021 Grand Design Momentum 28G
M_GO_BLUE1
Waiting for a response from my service advisor...
Francesca_Knowl
I can't believe there's a tow truck driver in North America that will stand by while you post questions on an internet forum!
If it's going to the dealership, presumably for service, why not call their service department and ask the folks that'll be working on it???
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
M_GO_BLUE1
I am not home right now...wife is home with the tow truck driver
ependydad
Does your owners manual mention anything about it?
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
