Towing Double?
08trdoffroad
Hey all,
I just purchased a 13' Aluminum boat and was curious if it would be possible to tow it double behind my 2010 Starcraft 176RB? The boat, trailer, and motor probably weigh less than 500 lbs, with maybe 40-50 lbs of tongue weight.
I have a few questions related to trying to do this.
As you can see in the picture below. The bumper is not very substantial.
Is is possible to swap out to a standard 4" bumper to allow the addition of a rear hitch bracket?
Or am I out in the night with the idea of trying to tow double with this trailer?
2008 Toyota Tacoma V6 Auto
2010 Starcraft 176 RB
44 REPLIES 44
Campfire_Time
08trdoffroad wrote:
I have an email into the manufacturer detailing what I wish to do, we'll see what they have to say.
08trdoffroad wrote:
We shall see...
You sound sure they will give you the thumbs up and that we're giving you bogus information. That said I'm not clear on why you are asking here. Many of us have been towing trailers for many years and have a lot of experience and knowledge. We're just trying to save you a lot of headaches and possibly even a lawsuit. If you want to do it, go ahead. Why listen to reason? I personally don't really care if you destroy your trailer and your boat all at the same time.
Chuck D.
โ€œAdventure is just bad planning.โ€ - Roald Amundsen
2013 Jayco X20E Hybrid
2016 Chevy Silverado Crew Cab Z71 LTZ2
2008 GMC Sierra SLE1 Crew Cab Z71 (traded)
Francesca_Knowl
In addition to asking the trailer maker, you might ask a professional welding shop for an opinion. Those guys mince no words!
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
08trdoffroad
We shall see...
popeyemth
The manufacturer is going to CTA and say no if they reply at all
"wine is a constant proof that God loves us, and loves to see us happy" ben franklin
08trdoffroad
Campfire Time wrote:
People have put bike racks on the light weight travel trailers, ignoring the trailer manufacturers recommendation NOT to put anything on the back of the frame or bumper, only to have it end in disaster because the frame was not able to hold up to the few extra lbs of the bikes and rack. I personally know someone who had a receiver welded to his trailer frame for a bike rack. They got lucky and a passing motorist warned him of the impending danger.
This is physics and engineering. The frame is designed to hold 3500#, yes. But on a platform mounted to the top of the frame. Not by dragging that weight bouncing down the road behind itself. The trailer frame is just simply not designed for those kind of stresses.
08trdoffroad
n7bsn wrote:
08trdoffroad wrote:
The frame handles the 3500 lbs of weight of the trailer, why would it not be able to handle the added few pounds of the boat. It's not like I want to slap on a 3500 lb boat...
Utah allows ball to ball towing as long as the combination of vehicles does not exceed 72 ft, and the lights on the rear-most trailer must function...
Do you understand physics? Do you know what lever-arm means? How a pendulum exerts force on the pivot point?
The frame on my 5er is 10 inch beams, and it's rated for a 1,000 lb trailer. Your frame is, what? 5 inch? Take a guess on the relative strength of the two frames.
Don't both trailers have to have working brakes also?
I have a grasp of physics..
Not in Utah. A trailer only has to have brakes if it is over 2000 lbs.
Campfire_Time
Chuck D.
TucsonJim
I'd suggest you contact the following for accurate information:
Utah Department of Transportation, 4501 South 2700 West, Salt Lake City UT 84119-141265; (801) 965-4000
I did a google search on "triple towing), and there is a ton of information out there.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
n7bsn
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
dewey02
Physically possible? Yes.
Safe? No
n7bsn
Cotay wrote:
I've read that no States allow "two balling" or "double balls", but I've never personally checked the law in every State. In California you can tow a bal trailer behind a 5th Wheel but not behind a Travel Trailer or other ball trailer. On our most recent camping trip we rented an F-150 to tow our boat and my wife drove the HTT behind our Expedition.
I know that both Montana and Texas allow "two ball" and think that Idaho might (?) also.
Cotay
08trdoffroad
I realize that, that is why I asked if I could swap to a standard 4" bumper, and if that isn't substantial enough I would be prepared to have the receiver installed directly to the frame.
Francesca_Knowl
This one....
n7bsn
1) I seriously doubt the frame on your Starcraft is up to the load of the boat-trailer.
2) The bumper is NOT strong enough, you would need to tie the receiver up into the frame.
3) I'm fairly certain Utah requires that one trailer be a 5er and that it does not allow both trailers to be a bumper-tow
