Trim size on 98 prowler?
Jonnygsx
Trying to figure out what size exterior trim I need on a 98 prowler 24lz. I need to replace the rubber inserts that cover the screws. I pealed some off today and it was all brittle and cracked but I forgot to measure the size and the trailer is stored an hour away. Any one have a prowler they could measure the trim on?
4 REPLIES 4
powderman426
I have a 1996 prowler fiver,and it uses 1" wide.:B
Ron & Charlotte
WD8CBT since 1976
32' Gulfstream Ameri-Camp & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
newman_fulltime
Yes it is generac trim if you order the wider it will have a higher arch if in a narrow channel.th majority that i have replaced on trailers has been the narrower but without a piece to compare or measure hard to say.
Jonnygsx
newman fulltimer wrote:
There are 2 sizes a half and one inch take a piece to the dealer parts they sell it by the roll or by the ft
As I mentioned the trailer is an hour away and Id like to order this now so I can put it on next time I go up. It appeared to all be the same sized trim on my trailer, or were you saying there are 2 standard sizes used and not being specific to my prowler?
newman_fulltime
