Trouble with black tank sprayer... baffling
bob2j8
I hooked up my black tank sprayer this weekend to flush, and absolutely no water was getting through to the tank. I've used this sprayer many times, but this weekend, nothing. I'm thinking it must be clogged or something. I even disconnected the vacuum breaker under the bathroom vanity and hooked it up directly to the outside hose bib, as well as hooking it up to my city water hose when I got home yesterday. Still nothing. its like the line has been completely blocked. I'm at a loss as to why this would happen. The trouble now is that my underbelly is enclosed and I have to remove a bunch of stuff just to be able to get to the sprayer. If anybody has any tips, please let me know.
2008 Ford F-350 King Ranch SRW, Powerstroke, Torqshift
2010 KZ Spree 318BHS
E2 Trunnion Hitch
8 REPLIES 8
l001952119
louiskathy wrote:
Ours got clogged with sand three years ago in CA. Never did get it to work after that. How do we know it's sand? We filter the water prior to it coming into the rig but we never thought about filtering the water when we flush the tanks. Duh. The filters were full of sand so it's a no brainer that the sprayer got clogged at the same campground.
I experienced the same basic problem. My use of well water at some campgrounds allowed small pebbles, shale, etc. to enter the flush system. This plugged the small orifices in the spray head. This can be prevented by using a screen washer in each water hose inlet fitting. I had an enclosed bottom shield and had to cut a hole in the tin and replace the nozzle. It's a guess where the head is located and can result in alot of incorrect cuts and patching!
Isaiah63
I had the problem and solved it with CLR (Ace Hardware) to dissolve calcium buildup. Poured it into the line between the backflow valve and black tank rinser and let it sit overnite and it's worked great ever since.
Isaiah63
louiskathy
Kathy
mooky_stinks
Isn't there a back-flow preventer that would be seperate from the vacuum breaker, in-line somewhere? Mine has one connected to the outside connection plus the vacuum breaker which is under the vanity. Like someone already said, that seems the most likely place to look?
2020 F150 XL Screw 4x4 6.5โ€box
3.5 ecoboost Max tow HDPP
7850 GVW. 4800 RAWR
2565 payload
2020 Cougar 29RKS 5th wheel
bob2j8
thomasmnile wrote:
EDIT: The "vacuum breaker" you speak of, is that the back flow preventer? How do you disconnect it? On our Jayco, that thing is connected to the Pex tubing with crimp connectors. If I was to remove it, I'd be staring at two tubing ends. Did you remove it from the tubing and "bridge" the gap somehow?
On my spree, I have 2 pex hoses with female threaded connectors. one goes from the outside hose fitting to the vacuum breaker, and the other goes from the vacuum breaker down through the floor of the bathroom vanity. I can easily unscrew the fittings. That is how I hooked up the outside hose fitting directly to the hose that goes down into the floor, bypassing the vacuum breaker. That is what baffles me. By hooking it up direct, the water should get through unhindered, but this is not the case.
E2 Trunnion Hitch
mike-uswest
Mine did the same thing years ago. I just went with one to put in from the toilet. I tried everything to break the clog down to no avail.
Mike
2019 Ram 2500 TCD, 4X4,
Arctic Fox 25Y 30'
thomasmnile
Could it be the back flow preventer installed between the black flush hose connection and the tank sprayer has malfunctioned? Would seem the most likely candidate as the cause.........
