V-10 idle rpm
colliehauler
What rpm does your manual transmission V-10 idle at?
Mine is at almost 1000 rpm and seems a little high.
5 REPLIES 5
DaveF-250SD
X3, Mine idles at 700 rpm, 2004 with automatic transmission.
2004 F-250 XL Super Cab short bed 4x4 V-10/4R100
1977 Chevrolet Scottsdale C-20 Trailering Special 454/TH400
pianotuna
Nomad II
Nomad II
700 rpm for my v-10 with auto tranny
Regards, Don
fla-gypsy
My auto trans idles around 700.
RoyB
Might be some info here from a FORD TRUCK forum that may help...
V10 IDLE SPEEDS
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
carringb
Mine idles at 600 RPM once its warmed up. Do you have a scanner you can plug in? A faulty coolant temp sender can cause this. However, so can a dirty throttle body or a stuck idle air control valve on the pre-'05 V10s.
2014 ORV really big trailer
2015 Ford Focus ST
