Vision 19.5's end caps help
Area13
So I finally ponied up and got 19.5's. I had Les Schwab install them yesterday and all went well except for the center caps won't fit.
My rear ones won't quite fit over the hubs and the front ones need to be open to access and turn my hubs. My questions are can I remove the center piece for the front ones? I tried to turn it and give it a little love without breaking it with no avail. I'm sure I just need new open ones for the front, but looks like they MIGHT pop out?
The rears won't fit over the hub. It get's close, but won't go in all the way, rubbing on the inside, hub too big.
I'm waiting to hear back from the place I bought them from online and also tried calling vision, all phone #'s disconnected.
2020 Outdoors RV 21RD
2015 F-150 FX4 5.0 3.73
11 REPLIES 11
Area13
Reddog1 wrote:
I'm thinking the hole saw will not like the chrome coating. I suggest hole saw from the back of the cap if you can. Even then, the chrome might tear.
Wayne
Good points.
Reddog1
Wayne
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Area13
Bedlam wrote:
I didn't run the caps on the front and used the deep ones on the rear. I have since sold the truck but do have a brand new spare pair of deep caps if you cannot get them.
They are charging me, PM sent. Gonna drill out 2 of the ones I got with a 3.5" hole saw for the fronts.
Area13
Thanks. Ya, still waiting to here back, so we'll see. I used my dremel on one of them and it fits the front fine, not pretty though, can't get a perfect cut. I figure I can get a 3.5" hole saw and drill out 2 of the 3 remaining for the fronts no problem. I'll see if they at least send me a couple of deep rears.
Bedlam
Moderator
Moderator
Area13
Thanks guys.
Buzzcut1
Nomad II
Nomad II
They sent you the wrong caps, you need the deep ones and yes they make a deep cap with the cut out to access your 4wd hub.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Reddog1
I am not aware of any. Being made of plastic, which is very thin, they would be easy to cut with a Drimel type tool.
They are easily removed with a
Philip screwdriver, two screws. You could remove them during those times you may need 4WD.
Toad: 91 Zuke
Area13
OK, mine are only 3" deep. Sounds like the place I bought them from will work with me, just waiting for a call back.
Do they make on open cap for front hubs?
Reddog1
I went through that years ago. In my case, I had a 2WD truck. They ordered 4 caps that were for 2WD. They reordered caps for the rear that cleared the rear hub.
My truck was 2WD so no need to remove the center piece. My caps were plastic. You could cut the center of the cap off to expose the hub locks. You could also just run without the caps. They are held on with two screws.
Wayne
Toad: 91 Zuke
bigfootford
Nomad II
Nomad II
There are 2 different sizes of Vision caps. The deep ones are 5" tall. Hopefully you have the shallow ones.. I no longer have them so I can not tell you the height. I would guess they were about 4".
I ordered my Visions from Les, along with my tires. The caps that came with mine were the shallow ones so Les folks ordered the deep ones for me... You might go to Les and they can get them for you.
Jim
2000 2500 9.6 Bigfoot,94 F250, Vision 19.5, Bilstein shocks, air bags/pump, EU2000, PD 9260, Two Redodo 100ah Mini's, Aims 2500 Conv/Inv, 200W. solar, Morningstar Sunsaver 15A/ display panel, Delorme/laptop for travel, Wave-3 heat.
