Propane cylinder and hose........WRONG HOSE! You need one with the big green nut and a threaded fitting.
The threaded fitting on new hose screws into TOP of your 2 stage regulator----use Yellow teflon tape (for gas)
The hose coming from trailer screws into bottom of 2 stage regulator....BUT you should replace that hose cause of 'stuff' being inside hose and those cuts to outside of hose. REPLACE IT!
Again -----------Yellow teflon tape for ALL connections
And might want to consider new regulator
