water pressure regulators
MarkTwain
Looking to replace my water pressure regulator. Which one is the best and why?
11 REPLIES 11
djtkach
Another fan of the Watts 263 series. Expensive but you won't regret it.
2008 Ford Expedition Eddie Bauer
2008 KZ Spree 290BHS
the_e-man
Using a Camco Stainless Steel RV Water Pressure Regulator. I like that this one is lead-free since it is used for drinking water. There might be advantages to one with a gauge, but this simple one works well for us.
2018 Grand Design Transcend 28MKS
2010 Ram 2500
Travel Trail Sail - Info on Travel Planning, RV Camping, Outdoor Living
edatlanta
263A for me. Full time 10+ years.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
ktmrfs
watts adjustable regulator.
2011 Keystone Outback 295RE
garyemunson
Amazon is your friend. Get an inexpensive one with a gauge. The small inline ones restrict the flow too much for my liking.
Lynnmor
There is no such thing as a flow reducer, only pressure regulators. The barrel shaped plastic and brass regulators can be restrictive and nearly all of that type are junk. You don't need to pay the premium price of a Watts, any of that type may be fine.
QCMan
Nomad III
Nomad III
Do you want a true pressure regulator or just a pressure/flow reducer? You will pay in money for the first and you will pay for the latter many times as they typically do not last long before causing problems.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Good Sam Life Member
Sjm9911
https://www.amazon.com/Camco-Pressure-Regulator-High-Pressure-40055/dp/B003BZD08U
I have one of these, works fine for me. If its not enough pressure, fill the tank and use the pump. I dont need one thats adjustable. You may require something diffent. I also have a plastic one. That gets used when i loose the other one!
2012 kz spree 220 ks
2020 Silverado 2500
Equalizer ( because i have it)
Formerly a pup owner.
Sjm9911
Ill take 2 plastic ones instead. Wholly cow thats a lot.
2020 Silverado 2500
bob213
Good ones are not cheap. Don't remember paying this much for mine but price of brass has increased. Any of the Watt's 263A models will give you good service and are rebuildable.
I have this one: 263A w/ oil filled gauge
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
bgum
Watts
Quality
