We looking for new TT. Have few model ideas
Camper76
Looking for new tt. We have it narrowed down to few coachmen Catalina, wildwood and avenger. Does anyone own one these models?
Thank you
Happy camping
11 REPLIES 11
djsamuel
A bit more expensive and a bit smaller; but I easily tow my Camplite 21BHS with my Ram 1500. Light (6000 lbs GVWR, 3600 dry weight) and very solidly built, especially for an ultralight. We've had ours for 4 years so far and are very happy with it. May be worth a look:
Camplite 21BHS
2013 Camplite 21BHS Trailer, Ram 1500 Tow Vehicle
Camper76
lawrosa wrote:
Youll be hard pressed to find a light bunkhouse with a seperate room you can close the door. There is another guy with a yukon looking for the same.
Lightest I could find is this salem from forrest river..
http://www.forestriverinc.com/product-details.aspx?LineID=170&Image=5063&ShowParent=1&ModelID=2408#M...
Your issue will be payload and tongue weight. Not what you can tow.
Is this one aluminum or wood frame?
Lwiddis
OP try....https://www.ramtrucks.com/shared/pdf/2011_RAM_Full_Line_Tow_Chart.pdf
lawrosa
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
kerrlakeRoo
Camper76 wrote:
kerrlakeRoo wrote:
Ok a little lean on your details.
How many travelling?
Ages if kids involved?
Size and features desired?
Tow vehicle and its limits?
Budget?
Handy? Able to do maintenance and repairs to used?
Frequency of use?
They build a lot of models, because there are a lot of different users, using them many different ways.
4 of us. 2 kids looking for bunk room that we can close the doors. Looking for something in 28'-30'. Tow vehicle 2011 ram 1500. Handy. We use it 3-4 times a year.
Ok Bunkhouses in that range looked quickly at Forest river hyperlites, 27BHHL or at Highland ridge ultralight UT3110BH. Both are over 30' total length, and in the 9000 lb weight range, have the separate bunkroom Tongue weights of at least 900, and when loaded for use should be 1200-1400 when loaded for travel.
TV Ram 1500, wide range of cargo and tow capacities, ranging from 1440 lbs to 1940 lbs.
Tow capacities range from 4450 lbs to 8060lbs.
The trailers I checked were 6-7 K empty, and around 9000 loaded.
4 passengers in truck, figure 600 lbs (kids grow) Gear in truck= ??
Tongue weight of trailer as listed is empty, add for propane and tanks, and batteries on tongue plus personal stuff in forward part of trailer.
There are other manufacturers and brands on the trailers, maybe someone builds a lighter one that I looked at, but the truck appears pretty limited. I think all these items together will be a stretch.
Your light infrequent use allows an ultralight or hyperlite model, most folks will tell you these extremely light trailers are not as durable, as more heavily constructed models. Being handy especially with an ultralight is helpful.
edit add on, I have a friend with a trailer like what you described, keystone outback 293UBH that is closer to what you may be able to make work. 7600 loaded weight, and with that about 200-300 lbs less in tongue weight.
Lwiddis
"Tow vehicle and its limits?" isn't answered by "2011 ram 1500."
"Size and features desired?" includes TT weight. Or should we look it up for you?
Don't make this like pulling teeth.
GrandpaKip
SoundGuy wrote:
You may consider having a Ram 1500 "handy" but you'd especially want to pay attention to gross tongue weight with the camper fully loaded and ready to camp vs your Ram's rather limited payload capacity. Exceed it and you're sure to also exceed it's coil suspended rear axle. ๐Ÿ˜ž
Umm...think he meant he was handy, not the truck.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
SoundGuy
2012 Silverado 1500 Crew Cab
FrankShore
Get a Jayco, they're built budget conscious and for light use.
2014 F-250
2014 Minnie Winnie 2351DKS (Traded In-Burnout-Use A Surge Protector!)
2015 Arctic Fox 22G (Great Trailer But Heavy - Traded In)
2018 Lance 1685 w/ Solar & 4 Seasons Package
1999 Beneteau 461 Oceanis Yacht
En Norski i en Fransk bรฅt - Dette mรฅ jeg se!
Camper76
Budget?
Frequency of use?
kerrlakeRoo
Budget?
Frequency of use?
