โSep-21-2016 06:33 AM
โOct-14-2016 06:16 PM
โOct-14-2016 05:07 PM
โOct-14-2016 09:58 AM
โOct-14-2016 08:20 AM
โOct-14-2016 08:14 AM
โOct-14-2016 07:06 AM
โOct-13-2016 08:56 PM
โOct-10-2016 08:46 AM
2BLAZERS wrote:
Always like the 990s AF. So what are your axle weights? Just curious if your over 9,250 on your rear axle or not. AF get heavy on the rear axle very quickly. Post when you can.
โOct-10-2016 08:14 AM
towpro wrote:
Well here is the fully loaded product, ready to leave on a trip. Diesel tank is full, water tanks are full (425 lbs), Gray/black are empty, two full propane tanks and two 27 series batteries. and most of the dry food for a week trip. (beer weight goes into trailer)
Trailer empty weight is around 2200 lbs which contains one 27 series battery and spare tire up on hitch
Loaded inside is a BMW R1200GS (600 lbs) loaded COG around 5% forward forward of center of axles.
Tong weight appears to be just over 350.
trailer is ever so slightly nose low hooked up.
my hitch is the factory 2.5" receiver with a Curt 34" 2.5" to 2" receiver extension. Rated at 450 tong 4500 lbs load in non weight distribution mode.
I do have a weight distribution hitch if needed, which would put my curt extension up to 600 lbs/ 6000 lbs, but I think I only have 750 and 1000 lb bars.
All that was done to truck is sway bar.
Link to full size picture
Truck appears pretty level to me :). Since our next trip is to a campground, I removed around 300 lbs of water
โOct-10-2016 07:17 AM
โOct-10-2016 06:46 AM
โOct-05-2016 01:55 PM
โOct-05-2016 11:50 AM
โOct-05-2016 05:37 AM
GeoBoy wrote:
Whoa, whoa, whoa, what happened to the AF 996? We have a 2016 AF 990 and we scaled out at 4,880 loaded with water and ready to go. Pretty close to GM's recommended 4,913 lb. slide-in camper rating. I added Timbrens and my GMC sets slight tail high, I can change that by taking out the 1" spacer and replacing with 1/2" spacer.
Did you add the weight of the Fox Value Pkg.?
