Hi all – I’m trying to make sense of all of the weight data that I have:
1 – Cat Scale Weight w/ Camper on – 10920
2 - Cargo Weight Rating Sheet – 2802
3 - GVWR (door sticker) - 11700
4 - Tire and loading (door sticker) occupants and cargo should not exceed 3668
So if I subtract the tire and loading sticker (3668) from the GVWR (11700), that means the curb weight of the truck is 8032. That seems about right on other ratings sheets I’ve seen for a diesel 4x4 crew cab so I’ll go with it. I’m assuming this is with a full tank of diesel & DEF too.
If I subtract the Cargo weight rating sheet (2802) from the occupants and cargo sticker (3668), that means they assume 5 passengers (console & bucket seats, no front bench) must weigh 866 or 173.2 each (I won’t tell my wife what Ram thinks she weighs..)
And then the final calculation, and reason I started this whole exercise, if the truck has a curb weight of 8032 and I subtract my loaded scale weight of 10920, the loaded camper is a hefty 2888 (full water tank & LP tank and truck had a full diesel and DEF tank, but no driver)
*Note this isn’t a perfect analysis because I had the tailgate off for the Cat Scale weight but I’m sure its incl in the curb weight. So the camper is probably another 50 lbs or so. Also not sure if driver is part of the curb weight but assuming no?
Did I miss anything?
Hallmark Everest pop-up truck camper on a 2014 Ram 3500 Cummins Turbo Diesel, 4wd, Aisin Auto, crew cab, short bed
