Wheel pressure rating
ssemalone
How do I determine the pressure rating on the wheels of my TT?
7 REPLIES 7
TundraTower
I had the same experience as WayneAt63044. I went to next load range tire and just changed to steel valve stems. I only needed 5PSI more to take advantage of the higher load range tires.
2013 Tundra, 5.7FF, TRD, 4WD, tow pkg
2014 Forest River Cherokee 264
Prodigy II / Equalizer 10K
103 nights & 12,700 miles since April '13
WayneAt63044
Check with the manufacturer, if you can determine that. I contacted mine when upgrading from load range C to D (50 to 65 psi). Their limit was based on the valve stem so I changed from rubber to steel valve stems rated for the higher pressure.
2012 Forest River V-Cross Vibe 826VFK
pulled by 2009 Ram 1500 Quad Cab Hemi
time2roll
fla-gypsy wrote:
gmw photos wrote:
Many wheels I have looked at recently do not state a pressure limit, only a load ( in pounds ) limit.
My 11 year old wheels only list a weight limit.
Find the weight limit on a tire inflation chart and there will be your pressure limit.
OP, post the wheel size and any rating along with the exact tire size and max psi.
fla-gypsy
gmw_photos
downtheroad
Look for a stamped # on the back side of the wheel/rim.
If not there, you might have to remove the tire and look inside the rim.
(dumb, I know, but that's where they sometimes put it.)
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
dave54
Should be stamped on it someplace.
So many campsites, so little time...
