โDec-11-2017 01:45 PM
โDec-12-2017 09:29 AM
thedavidzoo wrote:
They are the blue GBS cells from Elitepowersolutions.com. I got them through Larry at Starlight Solar in Yuma, AZ along with the BMS.
So far they are working great. I am having a few minor challenges with getting the cells balanced more (faulty BMS part initially drew down one cell). If you are not bottom balancing up front and keeping an eye on V and SOC yourself, they do require the BMS system to prevent drawing down too much or overcharging.
Weight reduction was one of the major factors for us. Huge savings per Ah, as was ability to draw down to 20% SOC.
My converter is the standard WFCO but I don't use the converter or alternator (or a generator) to charge the lithiums, only solar. Tried hooking up converter to charge the batts as a test, but the 10 gauge cable from converter to batts didn't seem to allow much amps.
Inverter is GoPower high-surge 1500W (surge to 3000W).
โDec-12-2017 08:56 AM
โDec-12-2017 07:24 AM
thedavidzoo wrote:
We have a much larger Northstar and more space to work with, 4 lithium batts, their associated junk, solar and chargers, fuses, and inverter.
We ended up building an easily accessible vented "box" beneath our fridge for one of the batts and the rest of the electronics. Rex sent us material to make it match decor. It takes up a little bit of floor space, but everything is very close and cables are short. Had to drill 2 holes in back of dinette to run cables between battery box and new box.
See here https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/28937969/srt/pa/pging/1/page/3.cfm
โDec-12-2017 07:17 AM
โDec-12-2017 05:55 AM
โDec-12-2017 05:45 AM
โDec-12-2017 05:43 AM
work2much wrote:
What type of batteries? In general sources of ignition are not advised in confined spaces with batteries but AGM could be ok, or sealing the batteries with venting as mentioned by sidecarfilp should be fine. The only other note would be that inverters can get hot and need space/venting as well.The only other note would be that inverters can get hot and need space/venting as well.
โDec-11-2017 10:29 PM
โDec-11-2017 05:58 PM
โDec-11-2017 02:45 PM
โDec-11-2017 02:40 PM
โDec-11-2017 02:01 PM
