Xchocks question
Snomas
Do I need use one or two X-chocks? I have always used plastic wheel chocks to keep TT from moving when camped but like the between dual wheel X chocks.
2006 WINNEBAGO ASPECT 29H Ford E450 Super Duty
2018 F150 Lariat Crew Cab, Coyote 5.0 L RWD
32 REPLIES 32
jdc1
Walaby wrote:
Xchocks are not supposed to be a "replacement" for regular wheel chocks.
Mike
Ditto......they cannot hold the weight of an RV trailer unless it's a Casita or Bollero (2,000 lbs).
rbpru
Quite frankly I have never found trailer movement to be an issue. I set the chocks as needed for the slope of the ground and that is that.
Perhaps it has never been an issue because I have a shorter 25 ft. 6500 # TT.
Even my worst case in KY where I had the tongue 30" off the ground and the back bumper off the ground by mere inches caused no TT movement.
I have driven over my chocks a few times but those cheapo yellow plastic types pop back after a few days.
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
beemerphile1
I see some are recommending the rubber chocks from Harbor Freight. I have them and don't like the design or shape. I recently got some chocks from Tractor Supply that I believe will be much better.
https://www.tractorsupply.com/tsc/product/barn-star-structural-foam-poly-chock-ts239?cm_vc=-10005
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
parcany
Huntindog wrote:
I tried the store bought brands when I first started. For the last 20 years or so, I ahve been using homemade ones. Two 4x6s cut into a wedge with a large 12-14' bolt and nut to tighten them. A lot of times I don't need them. When I am off level, I dig holes for the high side wheels. Lots of advantages to doing it like this. The TT cannot fall out of the holes, like ican off of blocks. The TT sits lower which is better for the steps and stability in wind. The only thing needed is a shovel which is a handy thing to have in camp anyway.
Don't take this the wrong way but it would be kind of hard to dig holes under the high side wheels when you are in a state campground when the parking area is tar. Out in the boonies would be ok. I use a homemade set of 4x4 chocks and the store bought x-chocks and it works out just great. Never had the trailer even think about moving while unhitching it.
hondapro
Throw the cheep plastic chocks in the nearest garbage can, get 4 of the hard rubber chocks from harbor freight.
Set the chocks properly,I set the rear chocks and slightly back into them then I set the front chocks put the truck into neutral and let it set into the front chocks the put the x chock in.
Steve
2023 Ram 3500 6.7 Cummins Turbo Diesel
2022 Keystone Sprinter 32BH
B&W Companion
spoon059
X-Chocks are meant to reduce the rocking sensation by preventing minor rolling of the wheels. They are NOT meant to replace actual chocks, which are meant to reduce the trailer from rolling away.
I use Fastway wheel chocks, as it does BOTH. It is an actual chock that prevents the trailer from rolling away and it reduces the rocking sensation by not allowing the tires to have that minor roll.
2015 Ram CTD
2015 Jayco 29QBS
Huntindog
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
tdiller
I use two.
Lwiddis
โ€œThey get tossed into the back of the truck so that thy are easy to get if we park on a steep incline.โ€
A good safe practice. I see many newbies not at all concerned. They donโ€™t even turn their front wheels into the curb when available. I moved once to get uphill from one airhead
BarabooBob
Large rubber chocks both ahead an behind both wheels. I cheat and have ropes attached to the chock to make it easier to retrieve them. They get tossed into the back of the truck so that thy are easy to get if we park on a steep incline. My wife throws one on each rear wheel of the truck, I let the truck roll onto the chocks and then put it in park.
I saw one gentleman parked on a steep road and his tranny was really stuck in park and could not be released. I pulled out my tow strap and released the pressure on the tranny and he easily shifted out of park.
Bob & Dawn Married 34 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
B_O__Plenty
You can easily drive away with X Chocks in place. Not so easy with regular chocks. Don't ask how I know.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
OleManOleCan
Lwiddis wrote:
X chocks are nice but Iโ€™d use wheel chocks also. Not plastic...Hard, heavy rubber. Five bucks each a Harbor Freight on sale
Using both Wheel chocks and X Chocks is a good investment in your camper.
Maybe that sounds like a belt and suspenders thing, but both types work together to make your camper more stable.
JIMNLIN
Started with wood blocks but after a couple of windy days I had to constantly reset them.
So I tried the plastic chocks... worse deal so I gave them to my bil.
I went with one BAL adjustable chock but found two eliminated all fore and aft movement.
Walaby
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
Snomas
I have the HF rubber chocks that I used on my DP and I would use them in conjunstion w/ the one X-chock.
