Mar-01-2012 05:53 AM
Mar-08-2012 08:40 AM
NewsW wrote:durallymax wrote:
All the kids out blowing smoke are experiencing the cylinder washing effect, where the diesel fuel "washes" the oil film off the wall.
All the more reasons why a former "coaling" machine, or a tuner equipped machine is basically worth its NADA wholesale price subtracting the full cost of drivetrain, brakes and tires and suspension replacement at retail.
Assuming they have not damaged the frame, interior, steering gear...
Mar-08-2012 08:03 AM
Mar-08-2012 07:54 AM
Capt Skup wrote:
Back to aviation for a second. Had me wondering about jet fuel in conventional diesel engines. Each morning or before each flight I would take fuel samples from all the low point drains of the aircraft I was about to go for a ride in. Half fill a mason jar, do the swirl test and if the sample was clear and no contaminents present, the norm would be to dump the fuel into the tow tractor's fuel tank. Usually I would guess I poured probably 2-3 gallons. Which by the way aboard the aircraft carrier would be powered by JP-5 anyway. I believe those tow tractors were powered by 2-cycle Detroit Diesel engines, and they seemed quite happy to be running on the jet fuel. Just find it interesting in regard to lubiticity of the fuel.
Mar-08-2012 07:46 AM
Mar-08-2012 07:42 AM
Mar-08-2012 07:35 AM
Mar-08-2012 07:29 AM
2003silverado wrote:
I know that it isn't good on any diesel to be dry cranked because the diesel is used to lubricate more than just the fuel pump, such as the cylinder walls.
Mar-08-2012 07:26 AM
hawkeye-08 wrote:
Look it up your self, I provided 2 links, you can search for more after you have a read on those. The first link talks about a new Delphi pump that has a patented shoe that certainly appears to fix the problem of the shoe turning and caused issues in the Bosch pump..
I figured if I left it at that, perhaps NewsW would find the patent mentioned in the article and copy it here.
Mar-08-2012 07:15 AM
Capt Skup wrote:
I for one enjoy reading the posts our new friend has kindly shared. I was a gas turbine engine mechanic for many years, so I am able to digest most of the texts. Basically I find that automotive fuel injection is catching up with aviation. Thankfully our high pressure fuel pumps while pumping dry JP-5, I never had a pump fail. I do have to wonder if our friend maybe in violation of some copyright laws, ie "No part of this document may be reproduced in any form, in an electronic retrieval system or otherwise, without the prior written permission of the publisher".
Mar-08-2012 07:12 AM
Mar-08-2012 07:08 AM
FishOnOne wrote:NewsW wrote:hawkeye-08 wrote:
I think Delphi has the answer to this Bosch pump problem. I had read that they patented the fix to the CP4 pumps and they also came out with a new pump that incorporated their patents. Bosch is too stubborn to pay Delphi the license fees for the better pump...
New VW with Delphi HPFS pump
... and of course the poster over on FTE that posted this..
http://www-odi.nhtsa.dot.gov/acms/do...003-45604P.pdf
The Bosch CP 4.X series of pumps are a family of pumps, with the same inherent design flaw, such that a law firm in Texas has a class action lawsuit against VW/ Bosch for it, you can find it at the end of the NHSTA pdf above on pages 316 to 333.
There is no factual evidence documenting the "design flaw" that have yet been made public.
I have as much faith in a law firm making such allegations as I have with FTE.
If there is a Delphi patent, give me the number or publish it --- lets examine the patent to see if it has any validity to the issues at hand.
Wow... Asking for legitimate data to back up such statement. Amazing!
Mar-08-2012 06:39 AM
Mar-08-2012 06:04 AM
NewsW wrote:
Let's take a look at Delphi's next generation solution .
Mar-08-2012 06:02 AM
NewsW wrote:
Here is the German Patent for Bosch that eliminates the need for a helper low pressure pump.
MASSIVE SNIP
