Ford's answers to the NHTSA 6.7 Investigation
ricatic
There was a request for a link to Ford's answer's to the NHTSA investigation posted on a previous thread, since closed. Here is the link:
Ford's NHTSA Answers to the 6.7 investigation
This PDF is over 20 pages long. There are some interesting statements contained in the documents. My favorite is the one where Ford says they buy the pump from Bosch as a "black box" and do no testing of the component. It is closely followed by the tantamount admission that the pump will not provide a long service life when exposed to the poor lubricity fuel found in the US. You will have to do the math using the sales versus failure tables for the US and Canadian trucks. Eye opening difference to say the least...
Regards
Ricatic
Debbie and Savannah the Wonderdachsund
2009 Big Horn 3055RL
2006 Chevrolet Silverado 3500 Dually LTX with the Gold Standard LBZ Engine and Allison Transmission
2011 F350 Lariat SRW CC SB 4WD 6.7 Diesel POS Gone Bye Bye
1,199 REPLIES 1,199
coolbreeze01
NewsW said:
"I think the whole thing is fuel lubed, not motor oil, and fuel is bled back to the fuel tank via a relief valve and also used as coolant."
I was wondering if fuel still circulated back to the tank. At what temperature? If warmer than air temp, could be a built-in moisture maker.......
2014 Sandsport 26FBSL
NewsW
BenK wrote:
Always wondered, but haven't had the time nor inclination to noodle it
out on how those injector orifices keep from carbonizing/choking shut
Must have residual fuel being pushed back by the combustion process that
then is the 'plug' that keeps it clean enough for the next million cycles...
Or the injection of fresh fuel is sufficient to eject any deposit buildup.
In gasoline injectors, at much lower pressure, they can get clogged.
I don't know if there are coatings used on the diesel injectors.
DLC is used in the injector plunger for at least a decade --- definitely on the Siemens HEUI unit injectors, but I don't know about the Bosch piezo electrics.
I have not heard of widespread issues with the DLC unless it is referred to as injector stiction.
Siemens sold the diesel injection to Continental.
Posts are for entertainment purposes only and may not be constituted as scientific, technical, engineering, or practical advice. Information is believed to be true but its accuracy and completeness cannot be guaranteed / or deemed fit for any purpose.
NewsW
blackeyed1 wrote:
I think I'll bring this stuff up to my high school buddy that used to be a GM engineer. He's like you guys that really get into high tech stuff. Most of this I haven't a clue what you are talking about but we all learn things by reading. 39 pages! Amazing!
Thanks for the message...
FYI, we don't have a clue what we are talking about either.
Just idle speculation and desk research.
If I only have $50m capital, $10m operating budget, a small staff of 20 highly qualified research engineers, and a project budget of $3m, plus the data from Bosch and Ford...
But I don't.
So it is just shooting the breeze.
BenK
Ah...don't forget that the piezo valve being slammed shut by it's own coil springs are
assisted by back flow combustion chamber PSI via diesel fuel being burned !
{edit}....another Ah Ha !!!!
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
NewsW
BenK wrote:
Ha!!!!! I'll bet the screw/gear pump was removed as a cost cutting measure...
In fact... Bosch engineers were bragging about how CP 4 is cheaper to build.. and delivered higher pressures.
blackeyed1
BenK
Benk wrote:
snip...
Redundant and wonder why?
snip...
NewsW
Think I have to do some digging on Bosch injector literature... to see what mysteries can we unravel.
BenK
NewsW wrote:
snip...
Rick -- show us the bearing ad seal material.. that is gonna be interesting.. real high tech.
Goodness, more thoughts on this new avenue
Organic amines...wonder if that also attacks and/or affects whatever
seal material(s) are in this system ?
That then leads to question if that might be the source of the mystery H2O...
Anyone pressure wash their diesel engine bay recently... 😞
BenK
That video doesn't do a good enough job of showing fluid flow, but it appears
to have both a piston and screw/gear pump.
back on the CP4...there is still the slam when the flow is stopped by the injector
closure
The piezo only opens it against all of those springs, that then slam it shut
after the piezo's turn off. Key is how fast it slams shut to then understand if
there are pressure waves in there going back to the pump & one way valve
That is the function of a 'properly' designed accumulator to absorb and
nullify or reduce down to 'background noise'...
NewsW
BenK wrote:
How is that lob lubed? Assume fuel and then where does it come from and
it should have a return or relief back into the fuel system somewhere
Asking because the cam shaft is also lubed some how. Then ask what kind
of bearing is used? Is that lube under the same PSI as the incoming
fuel to the piston/chamber?
Am getting at whether there is a potential source of contamination from
that bearing and it's seal?
Rickatic need to post pics of his disassembled pump.
NewsW
If it is a shock generated by the closure of the valve -- then the accumulator / injector is not really part of the problem.
What if you took a look at the CP 3, supposely a more complex and expensive design, and see how it was made simpler in the CP 4.
We know the CP 3 is good, at least at lower pressures.
http://www.youtube.com/watch?v=bHWbnP2l37Y
CP 3 video
Does it look like the CP 3 have a gear pump ahead of the piston pump vs. the CP 4 that is the piston pump only????
BenK
Just as thought...it uses the fuel PSI to self shut along with a coil spring
That is where the shock wave is generated...when that valve shuts and since
via the fuel flow/PSI, directly linked or back into the fuel lines
Any have tossed the cam lob as the potential culprit. That is where
my initial thoughts were, but after learning how it works, of course not
there...but...a new one creeps in...
BenK
Factored by cavitation, which creates dry/non-lube situations inside the chamber
NewsW
See if these videos shed light:
http://www.youtube.com/watch?v=HIok47p8zCw
Pump
http://www.youtube.com/watch?v=u-ZC1FaNDh0
Piezo injectors.
More injectors electronics:
http://www.youtube.com/watch?v=Yb0lEWHHDE0
